Torque specs in WSM: for dry or lightly oiled fasteners? | FerrariChat
Discussion in 'Boxers/TR/M' started by Supernaut, Oct 1, 2021.
  1. Supernaut
    Supernaut Karting
    Dec 3, 2019
    152
    Annapolis MD
    John Panek
    Couldn't find this in my 1983 BBi WSM or searching forums here. Installing cylinder heads. Should I clean head studs and nuts and very lightly coat with motor oil before installing or assemble dry? I know it makes a big difference in clamping force. What is the consensus here?
  2. pshoejberg
    pshoejberg Formula 3
    1,818
    Denmark
    Peter H
    Light coat of oil.
    Best, Peter
    Supernaut and turbo-joe like this.
  3. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    I don’t recall seeing it stated in the WSM one way or the other. In most all engineering documents, torque is assumed as clean and dry unless specified differently. In fact, most owners manuals clearly state clean and dry when quoting lug nut torque for the average laymen.
    When galling is an issue, most eng docs spec out the recommended lubricant as well as the torque. Antiseize is a lubricant too!
    If you see it in the TR WSM, please point it out. It is a good question.
    Qavion likes this.
  4. Qavion
    Qavion F1 World Champ
    14,241
    Ian Riddell
    Would this be of concern for even routine oil changes? I torque my drain plugs to a specific value, but I don't bother removing oil from the threads. TIA.
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    It is doubtful anybody cleans the oil off those threads. I use safety wire on those plugs and ‘barely’ hit the torque spec.
    Qavion likes this.
