Torque values for oil drain plug and for the nuts securing oil pan | FerrariChat
Discussion in 'Technical Q&A' started by dhs-9, Apr 28, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    Does anyone know the torque value for the oil plug as well as the 30 some nuts holding the gearbox and oil pans.
    Dave
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,634
    San Carlos, CA
    Mitchell Le
    I could not find the specs either, so I just use the tight enough method for the drain plug.
    For the small little nuts, 9 Nm is what I use. But those small torques are tough to get correct with big tools. I just use sealant around the gasket, and use a small 1/4 ratchet to tighten the nuts evenly but not too tight.
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    I tighten the drain plug until I feel the crush seal give. There is a distinct feel to the wrench when this happens. I'm talking about a new seal, not reusing an old one.
