Torqueing down a 308 head | FerrariChat
Discussion in 'Technical Q&A' started by paul 308, May 10, 2007.
  1. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    Having read recently that, on inspection, 308 head nuts have been found to be finger tight and being slightly concerned about pressurisation of the cooling system, I've decided to check and torque down the heads. It looks simple enough (doesn't it always!) but I would appreciate any advice and do's and don't's on the way. The car has only done 14k miles, albeit over 30 years, of which 7k in the last 4 years. Do I need new cam cover seals or any other bits to get it back together and oil tight?
    I can't see a nut tightening order in the manual but in the absence of other advice I'll go from the centre, alternating sides outwards per normal.
    As always, all advice and suggestions welcome.
    The car is a 1976 UK spec, dry sump, single distributor 308 GTB.
    TIA
    Paul
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I think you'll need a special tool for a start!
    http://cgi.ebay.co.uk/FERRARI-308-328-TESTAROSSA-CYLINDER-HEAD-NUT-TOOL_W0QQitemZ320110340880QQihZ011QQcategoryZ10380QQssPageNameZWDVWQQrdZ1QQcmdZViewItem.
    Its really not going to be easy to do - especially the front bank.
    Why not pop over to QV at Ascot & ask Mike Lester what he thinks....
  3. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Ah! thanks. Yes I'll give them a call. And there was me thinking I could just get a socket onto each nut and torque it up. Silly me! I guess you need that tool if you're not taking the camshafts off (which I would hope not to have to do).
  4. f355spider
    f355spider F1 World Champ
    18,043
    Common problem; if I recall correctly, the workshop manual even specifies a retorquing interval for the 308 series. I think it was with every major service...so every 5 years or 30,000 miles. I know that both my 308 and my 328 when in for a major service had the head bolts retorqued. The tech even told me my 328 had a couple that were a bit loose! I think he just retorqued and did not loosen first, because he said two bolts took a quarter turn to reach spec. He wouldn't know that if he loosened them all first...
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,529
    San Carlos, CA
    Mitchell Le
    You may not need that special tool for a 2V engine. 4V engine requires the tool. Lots of people feel that you need to losen and then tighten to spec. Many people simply set the torque wrench and go to town. I am of the latter.
  6. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    I have always (30 years) been in the loosen-then-retorque camp. I back them off about a quarter of a turn, then retorque to spec. A clicker-type wrench has been reliable for me. Keep your free hand off the wrench because it can affect the torque that the wrench detects. Pull steadily and smoothily, no jerking.
    Ed
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Second what Ed just said. I have found that if you dont loosen them first, they are usually stuck in place and you really arent gaining anything. When you back them 1/4 - 1/2 turn, however far it takes to turn freely, on retorque you will turn them back much farther than where they were initially, hence they are putting far greater pressure on the gasket and thats the whole reason you would do this. On heads that tighten down a ways, I let them rest 10 minutes and do it again. You would be surprised how much farther they tighten down.
    When retorquing, make sure you have as full of swing available as you can, because if it gets near max torque and you stop, they generally will "stick" there, and you can no longer torque it tighter reliably because you will have to far exceed torque spec to get it to break loose to turn, and then it will just get jumpy. Better to turn it through in one continuous motion without stopping until your wrench clicks.
  8. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Thanks for the responses. Mine is a 2-valve engine so hopefully I can get away without the special tool. I know exactly what you mean about a steady pull, otherwise you get 'stiction' and it doesn't go the full way.
    I guess I should get a couple of cam cover gaskets before I start. I doubt I can rely on the old ones staying oil tight.
  9. Glassman
    Glassman F1 World Champ
    Where exactly is the printed description of this service outlined. Is it in the owners manual or the service book?
  10. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Same with new spark plugs. I always hand tighten, loosen and then tighten to spec. Used spark plugs don't seem to need this however.
    Ken
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Gasket type spark plugs need to have the gasket compressed when new.
  12. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    I have a 2V car and you don't need any special tool. For my car the *sequence* is critical and it's in the service manual.
    From researching here I concluded it was best to do it in stages - three stages - working up to the final torque.
    I suppose head gaskets may not be any different than other gaskets. But, I admit when it comes to head bolts, I am in the group that just torques in place without loosening.
    Seamus
  13. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Static friction is always more than dynamic friction. If one retorques a bolt and it actually moves, you are probably good to go. If there is no movement, then back off the bolt, and retorque.
    If one were really anal about the process, it's probably best to back off the nut a good amount, lightly reoil the threads and mating surfaces with fresh engine oil, one bolt at a time, then retorque. This is the controlled status when new. I would follow the tightening sequence in the SM.
    Bill
  14. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I don't know about Ferraris in this regard but have found that after retorqueing the head it's a good idea to check your tappet clearances. Sometimes they can change a little.
    Bob Wassam
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    The Ferraris are all overhead cam, so any reduction in hieght would be irrelavent to valve clearance. It would however alter valve timing and loosen the belt or chain ever so small an amount.
  16. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Logic says that tightening down the head shouldn't affect the valve clearances but I recently built a Vauxhall twin ohc engine with solid (shimmed) followers and all 16 valve clearances reduced by 2 thou after torquing down. I must say I don't understand why. I can't believe the head was squeezed. Any suggestions out there?
    Back on the original topic, can I be sure that I don't need the special tool for a 2-valve head? It would be nice to know before I pull the covers that I can get the job done in a day and not have to go and look for the tool on e-bay.
    I was planning on backing off each nut in turn, oiling the thread and face and then pulling up to full tightness in one go. It doesn't seem to make sense to slacken them all off in reverse order and then pull them up in three stages (25, 60, 72 lbft) if you're doing them one at a time.
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    If your going to all the trouble to remove the cam covers, you may as well replace the cam oil seals too. No, you do not need any special tools, but one corner or so need a thinwall socket to get onto the nut. I used a 3/8" drive deep socket on those. 6 point sockets wouldnt be a real bad idea to be using either.
    But if your going to put in seals, you may as well check and alter valve clearance, and your only a skip and a jump away from changing the timing belts while your in there. I think you'll feel a lot better getting it all done.
  18. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    I am in agreement on all of the above. And, I have a 2V car and recently re-torqued the head bolts.
    I had no idea whether valve clearances could be affected by the re-torque. But somehow the thought did cross my mind. So, not knowing any better, I decided to make the re-torque the very first thing I did. I would be more worried about the belts and tensioners. And after that the valve clearances.
    Seamus
    P.S. I think there must be some law somewhere that states something like it shall not be possible to complete thy task in one day or verily in one weekend for lack of a special tool or discovery of the unexpected need for a part not within thine inventory :).
  19. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I believe its in the owners manual, inside the back page. But only in Italian.
  20. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Amen to all the above. However the belts and idlers were all replaced last year so, in the absence of tappet noise, I shall content myself with tightening the head nuts.
    Now what the heck did my son do with the torque wrench.....?
  21. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    Am I the only one seeing this snowball into a big long project?
    Lets see:
    Remove Engine cover & maybe find new things to fix but at a minimum:
    Cam cover gaskets $150
    Cam cover seals $160
    Distributor seals $ 50
    Timing Belts $ 80 The manual says never re-tension a belt
    Idlers $200 Might as well u're there
    Alt & AC belt $80 They don't like retensioning either
    Dizzy points & Cond $75 Its out & easy
    That about $800, plus say another 50% for incidentals makes it $1200 plus 40 hours of your time for retorquing bolts that have been happy for 30 years?
    Nay I say!!!!!
    Take car to Italy for short Holiday, upgrade something, or .......... whatever!
    As my dear dad said "If it works, leave the dam thing alone"
    Bill
    just my .02
  22. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Your dad was right on the money!
  23. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    I fear you may be right and I should leave well alone.
    By the way Birdman, I just did your carb float adjustment and tune up procedure and the difference is fantastic. No popping and banging anymore, even my wife commented how much smoother the car is running during a 500 mile round trip in France last weekend. Thanks a lot for the write up.
  24. Glassman
    I was wondering the same thing. Has anyone re-torqued the head and then had problems develop? Could this cause the gasket to start leaking as it has now been jarred a bit. Or am I out of my mind?
  25. dm_n_stuff
    Dec 10, 2003
    43,706
    26.806311,-81.755805
    Dave M.
    #25 dm_n_stuff, May 13, 2007
