Torquing Suspension Under Load | FerrariChat
Discussion in '308/328' started by wildcat326, Apr 20, 2016.
  1. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    #1 wildcat326, Apr 20, 2016
    Getting ready to change control arm bushings, and I have have one major fear going forward: If I keep things stock with rubber bonded bushings (my desire), apparently one must torque the bolts "only under load." I fail to see how one reaches the inner control arm bolts with the car on the ground and a wheel installed. Heck, with the shocks and hubs in place, they're not the easiest things to reach with the wheels off, and the car on a lift, let alone reassembled on the ground. Is this really straightforward, or am I misinterpreting "under load?"
    Anyone got a good How-To on the torquing logistics?
  2. Steve Magnusson
    26,936
    If the car is on jackstands, you can use a floor jack (with a wood block to protect things) to raise the outer end of the lower control arm (one at a time) with the wheel off into its near-operating position and then do up the bolts+nuts (of course, you have to be careful not to tip/topple the whole thing over ;)). Or, if Edd China had a car up on the ramp with the wheels off, he'd use a transmission jack to do the same thing.
  3. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    You can also torque the bolts through the bushings to the forks on the lower control arms on a bench before they are installed. I torqued the uppers with the control arm level with the floor before I connected the lower end of the shock and the hub. You will need to pull down on the lowers to connect everything but it will already be torqued and preloaded in the right direction.
    Basically... install the control arms parallel to the floor and torque them in on the frame side and then install the hub at the ball joints. You have to pull up and down on the lower one to hook up the shock and the ball joint but you wont knock your car off the stands.
  4. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    Thanks guys (and Mike for the phone call earlier). Feeling better about this.
