Tough getting into 2nd gear | FerrariChat
Discussion in '348/355' started by RandyT, Oct 31, 2016.
  1. RandyT
    RandyT Formula Junior
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    #1 RandyT, Oct 31, 2016
    I'm having a hard time getting my 348 smoothly into second gear. It gets a little better when it's warmed up, but only a little. Could it be a bad guide bushing or a simple adjustment? All the other gears are fine.
    Randy
    Freshman at Stooges University.
  2. JoeAsheville
    JoeAsheville Rookie
    Jun 15, 2014
    45
    Balky synchronizer tripping over the blocker ring, most likely. If the trans fluid hasn't been changed in a while, now's the time it seems.
    If that doesn't result in much improvement after a few miles of driving...then I'd look at other (more difficult/expensive) options.
  3. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    #3 Nader, Oct 31, 2016
    I've heard a change of transmission fluid to Redline 75w90NS might make shifting easier.
  4. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    - Fresh Redline 75-90NS or MTL per Rifledriver's rec.
    - Properly adjusted and lubricated shift cables
    - Properly greased shifter/trans selectors
  5. fatbillybob
    Aug 10, 2002
    29,184
    socal
    Come to next Stoogapoluza and learn how to fix it. Can't wait get the car to Plugzit and he will fix it. Show up at chuckwalla Stooge trackday and get it fixed 11/13/16 and drive your car as Enzo intended. So many options!
  6. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Thanks you guys!
    FatBillyBob, I was planning on bringing the GT40 to Chuckwalla, but maybe I'll just bring the 348 and have it fixed and adjusted.
  7. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    This is what I did and I found a 100% improvement.
  8. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    In life we have 3 guarantees;
    1) Death
    2) taxes
    3) difficulty shifting into 2nd gear in a Ferrari
  9. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Hahahaha
  10. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I agree with replacing the trans fluid with the Redline shockproof gear oil. Made a big improvement in my car. JGW
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Note to the OP: while several owners here have reported smooth (or smoother) shifting by switching to Redline Shockproof oil, Redline specifically recommends against using it in applications where an oil pump is involved, and our gearboxes do have an oil pump.
    Redline's online application guide does cover the 348 in case you want to see what fills they recommend for your car: www.redlineoil.com/application.aspx
  12. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    I just ordered the 75-90NS oil.
    Is it easy to replace? Anything I should know before I change it? ... Or is it pretty straight forward like any other car. The 348 book recommends 1.06 Gals. Does that sound right?
    Randy
  13. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,533
    Menlo Park, CA
    Paul Chua
    This is a common issue. "smg2" did the best explanation (with photo) I'e ever seen that explains the whole thing, as well as what you need to do to fix for good.
    View this thread for a ton of great info.
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/533459-true-fake-about-3x8-series-legends-just-legends-4.html
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,533
    Menlo Park, CA
    Paul Chua
    #14 paulchua, Nov 1, 2016
    All Credit (and photo) goes to SMG2.
    For me, I've switched to redline and skip 2nd gear for 5-10 minutes since I need to warm up the car anyways...so never a huge issue for me.
  15. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Great info! Thanks.
    I'm going to start with changing the oil with Redline. Is it pretty straight forward, like a regular car? Are there any DIY videos on changing it?
    Randy
  16. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #16 Wade, Nov 1, 2016
    Paul, sorry to say but the 308/328 gearboxes are completely different animals than what's in your Mondial t and the 348.
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Randy, while I know that the last 30k invoice doesn't specify what type of oil was used Bill prefers the Redline. Did you ask him exactly which type he used? Wouldn't want to use the same again if that's the problem.
  18. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    Hi Wade,
    Did you make it through hurricane William all right?
    I already ordered the Redline oil recommended in an earlier post. I'll try that first. All I need are the steps on how to change it.
    I saw a video on youtube with a 360 and they said:
    1. Remove fill plug.
    2. Remove drain plug.
    3. Remove and clean filter.
    4. Tighten drain plug and filter.
    5. Add 1.06 gals. of Redline 75-90NS oil (for 348).
    6. Tighten fill plug.
    7. Check level.
    Does that sound right? Should I use a pump to put the oil in?
    Randy
  19. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Hi Randy, yes, we breezed through the 'cane without issues, thanks. :)
    Here's Pap's thread on the 348 gearbox oil change, good stuff!
    http://www.ferrarichat.com/forum/technical-q/101885-pap348-gearbox-oil-change.html
    Still, I'd check with Bill. There are lots of "variables" regarding oils for Ferraris. What works for one may not be the same as for another (hence the debates). So if you use the exact same that's already in there then you may just replicate the issue.
  20. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,533
    Menlo Park, CA
    Paul Chua
    #20 paulchua, Nov 2, 2016
    Thanks Wade for the info - awesome diagrams.
    I just assumed the same 1st-2nd hesitation was caused by the same oil compression into the machined recess in the side casting, I am by no means an expert - so I'm sure somebody else can chime in here.
    The relief hole fix for the 1st-2nd gear hesitation may not apply to the 348/Mondial t.
    I attached the original article in Prancing Horse if anybody wants to read it.
    Cheers
  21. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    #21 Jh348, Nov 2, 2016
  22. WATSON
    23,839
    WI
    Be careful there. Redline has dropped the recommendation of using the Shockproof gear oils in the 348 & 355 due to "flow issues". The 355 in particular with the oil heat exchanger. I quit using it last season as it seemed to be awful notchy and worse cold.
    From Redline's site:
    The 75/90NS is the ticket and what they recommend and is better in my 355. Perhaps an improvement in the 348 as well.
  23. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    You will need about 4 and a half bottles of the Redline (they are 946ml bottles)
  24. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Great point, and a reason to determine what's in the car already.
    Another example, the exact same car, shifted perfectly in Florida for a few hundred miles after its 30k service and, a few hundred miles later while in CA, second gear is now "difficult". Same car by VIN.
  25. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,544
    Jeff
    When I first got my 348 I couldn't use 2nd when cold but even when warm it could be problematic which really spoiled the driving experience to the point where i would try and miss out 2nd if I could.
    After reading around the forums etc I came across the redline superlight superlight shockproof (I tried the NS before with no joy) and it really improved the shifting so there was no difference between when it was cold and warmed up.
    This is what I did:
    Transmission/Gearbox Oil Change using Redline Superlight Shockproof Oil
    Anyway still not good as I liked so again after reading around I decided to clean and relubricate the shift cables which vastly improved the feel and pretty much got rid of the 2nd problem shifting. see below:
    348 DIY "Restoration" - Page 149
    Finally, and by "chance" my slave cylinder housing "Burst" so had to be replaced along with a full change of brake/clutch fluid.
    Clutch Slave Cylinder Release/Throwout Bearing Replacement incl. Triple Seals
    Now the car shifts perfectly from cold just like an ordinary car - even if it hasn't been driven for weeks :)
