Tough 'second' starting of my '77 308 | FerrariChat
Discussion in 'Technical Q&A' started by PeterS, Jun 28, 2004.
  1. PeterS
    PeterS Five Time F1 World Champ
    52,669
    Goodyear, AZ
    PeterS
    When I first start my car (when cold), it fires right up. When it is warm, it takes about 15 seonds of cranking to get the engine to turn over. I tried going from High Octane to Low and that did not help. Where would be the best places to troubleshoot this one?
    Thanks in advance,
    PeterS
  2. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    It would seem that your cold start injectors are pushing "extra" fuel into the engine, when warm............they should be shut off, when warm. The problem would be either, one of the cold start injectors, or the thermotime switch.
  3. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Peter, your car is carbed, correct? Cold start injectors are not the issue then :).
    My carbed 308 also did this, as did many other people's carbed 308s--it's like a carburetor version of the "hot start" problem. Many folks are of the idea that it's "vapor lock," or otherwise related to the heated fuel in the very hot carb bowls as the engine cools off when stopped for a short while (like going into the store or something).
    I've read of people "flooring" the accelerator during starting to get this taken care of. I tended to adopt the "five seconds of cranking then then tap the throttle a few times till it starts to catch" approach...
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,693
    Hell's waiting room
    I've read of people "flooring" the accelerator during starting to get this taken care of. I tended to adopt the "five seconds of cranking then then tap the throttle" approach...[/QUOTE]
    Flooring it to get it started? That could be scary!
    I have a similar problem with my '78 but like you say if it doesn't fire right away just a little feathering or light tapping of the throttle always does the trick!
  5. henryk
    Dec 9, 2003
    479
    Door County, WI
    You are right, Mike. I didn't realize that this was a carb car!!!!!!!!!!!!
  6. PeterS
    52,669
    Goodyear, AZ
    PeterS
    Yes, it is carb'd. When doing the consecutive starts, I tap the gas 3-4 times brfore turning the key and feather the pedal while cranking. Same problem...Think I should take it back to Wayne? (JUST KIDDING!)
  7. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    I had the same problem with my Dino. Jim Summers at Scottsdale Ferrari advised me to floor the accelerator and crank the starter. It works every time.
  8. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Make sure you allow the pumps time to fill the float chambers before you try to start it. Turn the ignition on and then wait 15-30 seconds before cranking, hot or cold.
    If cold, once float chambers are full (pump slows down), give 3-5 full pumps of throttle to squirt fuel in, then tickle it as you crank.
    If hot, just progressively open the throttle until it fires, if you miss it DO NOT lift off and re-throttle it. Just leave your foot wherever it got to and try again.
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    My '77 has the same issue. I find that this procedure works well:
    1. Turn the ignition key to start the fuel pump. Let it pump for 10 seconds. If it's quiet around, you can actually hear the fuel going into the carbs and the air "bubbling" out.
    2. Give the accelerator 2 good pumps to prime the system.
    3. Push the accelerator down about 1/3 of the way and crank. It will light right up.
    I have found that "diddling" the accelerator (i.e. pumping lightly) during cranking does not help and in fact, almost always causes the engine to take a lot longer to catch. Holding it perfectly still 1/3 open works for me.
    Nothing quite as ambarrassing as your Ferrari not starting in the gas station with everyone watching (which they always are)!
    Birdman
  10. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Peters,
    According to my owners manual, it says that when starting the carm warm, it may be necessary to fully depress the accelerator upon starting. I have a 79, and it takes a while to start if warm unless I do this. So I do it every time. If you're uncomfortable with flooring it, opening it 3/4 while cranking it will work as well. Then as soon as it starts, let off the gas.
  11. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Yes, as stated by others, gas pedal to the floor when hot. Works on my Lotus every time. It was scary the first time but I've never flooded it.
    Ken
  12. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Holding the pedal to the floor is standard proceedure for a car that has been flooded with fuel, if and when that might happen, say from a stuck float or pumping the throttle too much during crank over.
    Just need to get more air in there
    When hot I crank mine over with no throttle then apply about 1/3 to 1/2 throttle and it fires right off.
