Tow a 355 without a hook? | FerrariChat
Discussion in '348/355' started by unormal, Dec 24, 2010.
  1. unormal
    unormal Rookie
    May 22, 2009
    21
    Probably going to tow my 355 down to get serviced in the spring, but I'm curious how you guys would get it on a truck without the hook. I don't have the toolbox, and the tow-hook hole is probably too corroded to trust anyway.
    Maybe some of those nylon tow straps around the rear wheel struts?...
    Anyone done it before without destroying their car? :)
  2. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    893
    San Marcos, CA
    Vas
    There are frame/body plugs on the underside of the frame that are covered with a rubber grommet. When removed there are holes that you can hook the straps to for pulling the car onto the flatbed. I had mine flat-bedded a couple of weeks ago for a repair and the tow truck driver said he uses these rather than the tow hook.
  3. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #3 sambomydog, Dec 24, 2010
    If its only going in for a service...........drive it on the truck;)
  4. unormal
    unormal Rookie
    May 22, 2009
    21
    #4 unormal, Dec 24, 2010
    Well, it looks like it's leaking oil from somewhere, so who know's what's going on inside!
    If it was just a plain old service, I would (and have) happily drive it the hundred miles to the mechanic ;)
  5. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    So its going in for an engine/gearbox repair then and not a service?
    Saying that if its JUST an oil leak.....drive it on;) Or are you not running the car at all?
  6. unormal
    unormal Rookie
    May 22, 2009
    21
    I dunno, it's probably not bad, it was smoking a bit when I last drove it, and it's not gushing oil or anything, just a small leak (which may be power steering fluid, since it's reddish, but smells like oil to me, I'm good with computers and software, not so much cars and mechanics :)) so it really would probably be easiest to just drive it on.
  7. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    You know, about 9 years ago my 360 had a flat tyre in Italy while on holiday. I had no puncture repair can or tow hook even:rolleyes:
    I called the recovery service and while it was coming that's when i realised i had no tow hook because i left the tool kit at home like a plank. I was all pissed of with my self and tried to explain the situation to the recovery driver. I was on my knees trying to locate a suitable tow point, i was so frustrated. The driver looked at me in a confused way and just simply indicated to me with his hands while saying, "drive macina on" LOL! I felt like a nob:D
  8. jim94-348
    jim94-348 Formula Junior
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    Great story. I think we all have times that we can't see the forest through the trees.
  9. wiley355
    wiley355 Formula Junior
    539
    Vancouver, WA
    Wiley
    I feel dumb asking this. Went to use my tow hook fitting for front license plate mount, removed the rubber plug, and found the tow fitting covered by a metal blank (like a slug) with a slot on the bottom. I can't figure out how to remove it.
    Anybody encounter this? With the blank there I am unable to install the tow hook if I ever needed to use it.
