TPMS failure | FerrariChat
TPMS failure
Discussion in '612/599' started by doctorj!, Mar 24, 2014.
  1. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    What causes this and what needs to be done? I know my right rear tire keeps throwing off a sensor that it's punctured when it's not. What do new sensors run?
  2. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,864
    New Jersey
    Dominic
    AJ,
    The batteries in the sensors have a life span of 5-7 years. Most likely your sensors are going bad
    I just replaced the sensors on my 575.
    I bought them from Tire Rack. There are direct replacements made by Beru, The same company used by Ferrari for a lot less cost.
    -Dominic
  3. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    Thanks for the info! What did they run? The dealer I called said they're $200 each.
  4. Hawkeye
    Hawkeye F1 Veteran
    8,180
    The are $89 each. Go to TireRack.com and select WHEELS then add wheels for your 599 to your shopping cart. Then it will ask you if you want to add the TPMS sensors to the order, select yes. Then, go to your shopping cart and REMOVE the wheels from the order, leaving the TPMS items by themselves, then checkout. You'll have them in a few days, take to local shop and replace. Easy. I do this with my own 599. Then simply hold down the calibrate button once installed and you're good to go!
    www.tirerack.com
  5. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    Got it! Thanks!
  6. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Oddly when I bought the replacement sensors from TireRack for my '07 F430, they could not be read by the control unit. I had to return them and buy the Ferrari part. So it may be a hit or miss thing.
  7. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    I bought TPMS sensors for my MY05 430 from TireRack. I had to sync the system a couple of times before everything worked properly.
  8. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    If they are talking, break down, install, remount, balance and re-calibrate that's probably about right. I had to get this done a little while back too on the 599.
  9. tazandjan
    39,170
  10. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    My Ferrari dealer sent me Maserati TPM's, the exact same ones as Ferrari but saved me about $40.00 per sensor.
    The Ferrari box is expensive!
  11. Melanzane
    Melanzane Karting
    Sep 12, 2012
    173
    Florida
    Word of caution, if your old TPMS sensors are in or near your car (e.g., in a bag in trunk) it will screw up calibration.
  12. tazandjan
    39,170
    Affirmative, toss them in the shop's trash, not in your trunk, or the system will try to talk to all of them, confusing it greatly.
  13. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    Replaced the back right sensor but calibration is still not coming on. I guess the other three will need to be done too...
  14. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    But wait........there is more.....
    So after I thought that my sensors where fixed the the front left sensor started to play up again!
    And when the new clutch was installed Ferrari advised that it was the control unit on my sensors that required replacement.
    So 3 sensors later and a control unit $1,500 in total. Now the stupid thing is fixed!
    What a nightmare.
  15. tazandjan
    39,170
    CM- Very unlucky.
  16. Lone Wolf
    Lone Wolf Formula 3
    Oct 24, 2006
    1,085
    Highway to Hell
    i'm assuming you can't just replace the battery in the sensors?
  17. tazandjan
    39,170
    Nobody has tried yet that I have read about. Been done on alarm sirens, but those are not whirling around at X000 rpm, so probably not a good idea.
  18. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,785
    Weston, MA
    Paul
    I bet if you could, the "special" batteries would cost almost as much as replacing the whole unit. ;)
  19. tazandjan
    39,170
    Paul- Not sure I would want something glued back together in my wheel with a potential of it spinning 10,855 rpm at top speed (8250/.76)
