TPMS light | FerrariChat
TPMS light
Discussion in '458 Italia/488/F8' started by Sprucemoose, Jan 25, 2019.
  1. Sprucemoose
    Sprucemoose Rookie
    Jan 27, 2014
    10
    Amarillo Texas
    Question on TPMS light...
    So I had new tires installed on my '10 458 6 weeks ago, went with pilot SS same sizes as originals. Anyways since then my TMPS light is on and won't calibrate. I've checked pressures and their normal.
    My problem is I actually live several hours away from my dealer so I can't just run it by.
    I called the dealer and they said I'd have to bring it by. Could they have made an error with install? This didn't start until new tires.
    Or the batteries in sensors?
    Is there a way I can check/fix this on my own?
    thanks for the info!
  2. 458-Italia
    458-Italia Formula 3
    Jan 10, 2014
    1,726
    France
    I suspect that the sensors could have been damaged during the dismantling of the tire: they are flush and very fragile
  3. Cigarzman
    Cigarzman F1 Veteran
    Remember you must be rolling to reset the TPMS. It will not reset while the car is in a stopped position. Best , Kirk.
    Solid State, Bob Sullivan and kandi like this.
  4. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    TPMS sensor batteries tend to last about 7 years. Likely this is a coincidence and you will need to get new sensors. One of the downsides of having TPMS.
  5. Bob Sullivan
    Bob Sullivan Karting
    113
    Great Falls, VA
    Dr. R. A. Sullivan
    Thanks for this reminder! I knew this from somewhere but forgot. Thanks to your hint my TPMS is now reset.
    Cigarzman likes this.
  6. Solid State
    Solid State F1 World Champ
    10,575
    Maximus Decimus Meridius
    I'm shocked that the dealer (if same as tire installer) did not reset the TPMS warning during the test drive as part of the install unless they didn't even bother to test drive it which would be pretty lame IMO. Good work Kirk helping a fellow FCatter out. :)
  7. rttj777
    rttj777 Karting
    Apr 3, 2014
    72
    Georgia
    If there ever was a true "Love-Hate" relationship, then TPMS on any car, is it.
