TPMS Reset Driving Me Nuts! | FerrariChat
Discussion in 'California/Portofino/Roma' started by russellmcg, Dec 22, 2021.
  1. russellmcg
    russellmcg Formula Junior
    Aug 3, 2014
    492
    Houston
    Russell McGuire
    Howdy, boys and girls! As the title says, I am having issues getting my TPMS sensor to reset.
    I got in my car the other day, and the tires were low due to the weather being cold. So I aired them up, and my sensor is still on.
    I tried putting the car in park and resetting it, comes back on. I tried turning the car off and putting the key in position 3 and doing it, the same thing.
    Any advice on this one?
  2. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    766
    Nashville/Destin
    Steve
  3. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,553
    Austin TX
    Try setting tpms calibration mode and then, immediately drive 3-5 miles at highway speeds, that should resolve as long as the pressures are at or a little above spec.
    tomc and russellmcg like this.
  4. kd126500
    kd126500 Rookie
    Jan 5, 2021
    34
    Just went though the same issue due to the cold weather. After reading the forums, I raised the tire pressure to 40 lbs then went though the reset process. Of course it didn't work but when I reduce the pressures to the correct PSI and did the reset again, when I drove off the system reset itself. Who knows but it worked.
    Bill Phillips likes this.
  5. Redneck Slim
    Redneck Slim Formula 3
    1,636
    Palo Alto,CA,USA
    Walt Kimball
    Set the pressures cold and then do the calibration at every opportunity. Before starting. Before shutting down. Before the next start. I did it about two dozen times and finally it calibrated. My wheels were removed for machine polishing and the system wouldn't calibrate when everything was back together. Italian electronics.
