TPS problem | FerrariChat
TPS problem
Discussion in 'Technical Q&A' started by cavallo_nero, Jun 10, 2010.
  1. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Hi folks. I have a weird scenario associated with my fuel injection setup I did on the 308 GTS. I am running electromotive tecGT with TWM throttle bodies.
    Ever since the install, the Throttle Position Sensor does not output a voltage while the car is running. With the key on , I can see the voltage change in accordance with activating the throttle. Once the engine starts, that signal goes away. In troubleshooting, I can pull the TPS off the throttle shaft, and while the car is running, I can manually rotate the sensor and see the corresponding voltage change, but once I mount the sensor on the shaft – the signal goes away. Wiggling wires, loosly mounting the sensor, etc has no effect once the sensor is installed.
    Puling my hair out on this one, the folks at electromotive are stumped – they even sent me a new ECU and it did not help, and I bought 2 new TPS sensors ,and that didn’t help either.
    Any thoughts??
    john
  2. fatbillybob
    Aug 10, 2002
    29,261
    socal
    here is a total WAG...what happens if you manually move the tps like you say to see an output voltage but keep the tps as close to the installed position as possible? Is there any chance of some weird EMF thing going on like from the plug wires or interference like radio interference? That is really weird a tps is just a potentiometer and a very basic device. What about tps wires routed near sparkplug wires?
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    On the bright side at least we know what the problem with TPS load tuning was.
    Do you have a scope or access to a scope? I would be wanting to look at the trace from the 5V and output line. I’m thinking you have a either a vibration problem or the mount is forcing the something apart probably the latter……does the signal go away with the TPS in place but not bolted? Does it work if it’s in place but the screws are loose? How about it you hold it tightly in place by hand? Does the TPS sit flat and nice on the mount? Does it slip on easily? This is where I would be looking.
  4. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    If you changed the ecu and the TPS, then the issue must be in the wiring.
    One thing to check, with the TPS connected, remove the connector from the ECU and using a ohm meter, check the 3 connections while someone is moving the thottle.
    I just checked my wiring diagram for the TEC3 and I see I wrote in a change for the TPS connection. The Gray/Red Strip wire goes to C (+5 volts), the Dk. Blue to B (Thottle Signal) , and the Black/white strip to A (Sensor Gound) terminals. Obviously, something was wrong with the original wire diagram.
    Good luck.
  5. robert_c
    robert_c F1 Rookie
    May 12, 2005
    3,417
    SoCal
    Robert C
    You probably forgot the cover sheet. Didn't you get the memo?
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I could only guess that it might be a software problem. I say that assuming that TPS function can be disabled or enabled via a laptop at setup. I don't know if that's actually the case. If it is then I would think it's enabled with the key on and somehow disables for whatever reason when the engine running signal goes back to the ECU.
    Is there some new version of the software that is on both of the ECU's?
    I know this is far-fetched and then you would have to wonder why they're aren't numerous other complaints of this unless other people aren't noticing it (it goes into some default mode and the cars run okay using other inputs only).
  7. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I have been doing some research on this. I am going to go with a different tps sensor on another shaft on the TB'S. It seems , that the tps i am using is not preloaded on the shaft because i swapped the way the throttle plates open on the forward bank of cylinders. this caused the tps to be installed with no preloading, ie: should read about 1 volt with throttle closed - while i am currently reading zero volts with throttle closed. this is just a huncha nd i dont know if it will fix the issue, but it is all i got so far, and i realy think i narrowed it down to the sensor itself. thanks for all the suggestions - this is mind boggling.
    and yes, this is why tps/map blending was playing havoc with my driveability....
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Interesting. Maybe the fact that the TPS is providing no expected input (0 volts instead of 1) indicates to the ECU that the TPS is defective. Then the ECU ignores any signals from the TPS or otherwise defeats the TPS input/calculations.
    In any event, certainly sounds like you're on the right track.
  9. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Giovanni,
    Any resolution? FYI, I just checked my TPS settings - 0.37v fully closed and 4.94v WOT. Using an early style GM TPS.
  10. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I installed the new throttle body shaft (with the D-slot for the TPS) on the rear bank throttle body. Put in a new sensor and new connector. Well, the sensor now reads correctly – whew!!. I am not sure what the problem was, I am getting a better preload signal (.35volts), maybe that has something to do with it. Next week I am off to the dyno and hired a tuner to help dial in this whole business – I am mainly concerned with driveability as the car pulls strong to 8000 RPM!!!!! i will post the dyno results in my other thread on the conversion proccess (webers to TWM) sometime next week.
    thanks everyone!!
