TR A/C belt replacement | FerrariChat
Discussion in 'Boxers/TR/M' started by barabus, Sep 9, 2008.
  1. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    #1 barabus, Sep 9, 2008
    Following on from my alternator belt replacement i have to change the A/C belt too. The belt ive been sent does'nt look anything like the old one which had a smooth narrow V, this ones got a broader V and is stepped, does anyone know if this is correct as this is the 2nd try as the 1st belt sent was way too long? Also any tips on getting it on gratefully accepted i've had a go and it's a SOB !
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,934
    The Cold North
    Tom
    Give them the number off the old belt...no issues after that.
  3. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Instead of trying to match it up, just pay the F pimp this time around. I buy mine from the F dealer as I know they will have the ones that fit properly.
    To put it in, again remove the black grill over the AC compressor/Alt.
    At the bottom of the AC compressor, there is a pivot bolt just above the timing belt housing....loosen it, but you don't need to remove it.
    Loosen the tension adjuster "clamp" bolt on top of the compressor.
    Unwind the tension bolt and push the compressor downwards.....lots of room now.
    Slip belt on and reverse your steps or.....click your heels and repeat " there's no place like home...there's no place like home " ( only works if you have red pumps on ) :D
    ** The pivot bolt is usually very tight and there's not allot of room to get very much leverage. I put the car on jack-stands and go from underneath. There is enough room to use a ratchet with a good long extender to break it loose....this will save your knuckles and your sanity...ask me how I know. :)
    Shamile
    Freeze...Miami Vice !
  4. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Thanks mate but..............how do you know :D
  5. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,643
    wisconsin/chicago
    bo
    The AC belt isn't too bad... The alternator belt is a b*tch.
  6. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Sounds promising. Yikes... I hope my belts last till my major. Question: Is it normal that I get a squeal from the belts on cold start up. I am referring to the alt and a/c belt. After first start no squeel at all. Even if the car sits for a few hours.. Just was wondering only on cold start / overnight.
    Robbie
  7. bpu699
    Dec 9, 2003
    17,643
    wisconsin/chicago
    bo
    #7 bpu699, Sep 12, 2008
    If it squeals, you will soon lose a belt on the road... Been there, done that...
    I always wondered if sandblasting the pulleys during a major might provide for added friction so that these belts don't need to be aggressively tightened...
  8. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Noooooo......I told you not to ask!! :D
    Seriously though, when I was changing my belts for the first time, I just could not break loose the pivot bolts on the Alt. or AC. I tried and tried with every wrench and scraped my knuckles on the Alt fan and so on and so on. I said " hell with this" and jacked up the car, went from underneath, put a socket on the bolt with a wratchet handle and a very long extender. With the force I could exert with the extender, I broke loose the pivot bolt with literly a couple of fingers pulling. ....ahhhh.....physics at it's best !
    Shamile
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Chairman,
    This is not normal....that's why you need that update kit....no squeeling at all from mine.
    Your belt is glazed and is slipping and will snap soon. Don't worry, this is really an easy DIY job. Do as I described and lay on top of the engine with your head forward of the engine cover/rear brake light. You can easily put the belts on once the bolts are loose.
    Shamile
  10. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Bringing this back, seeing as it's A/C season. 1990 TR. I need to install a belt on the compressor. Sounds like loosening the pivot bolt(s) is best done from below, I put her up on the lift Saturday night and looked (prior to reading this thread today). It would appear that removing the oil filter would give lots more access to reach up to the pertinent area, or was I over-thinking this?
    Anyone have the part number for the belt, or who is a suggested dealer to order it from?
    TIA :)
  11. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    #11 302Tim, May 5, 2014
    Can't help with access question but I would hope you could loosen without removing the filter--not that that's a big deal. The F PN is 122973. Cost is ~$40.00 at Ricambi (Ferrari, Maserati, Lamborghini Parts Diagrams: Model = Testarossa (1990)). Can probably be found cheaper but they have good stock and service (and are a sponsor here).
    The spare I have in my jack bag (don't know if it is original) is a Gates belt, their PN 8904-0800. No guarantees on this though, I have never used/fitted it to my compressor.
  12. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
  13. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,260
    Mel
    Hee ... thats a good one Ken ! :)
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,515
    romano schwabel
    this shamile already told in thread 3
  15. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Yes, I was looking at removing the narrow screen. Just checking my options.
    Tim, thanks for the part#. I'll get her ordered up.
  16. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Ordered! Now I have something to do next weekend.
