News
TR Clutch Q
Discussion in 'Technical Q&A' started by TR Mark, May 8, 2004.
  1. TR Mark
    TR Mark Rookie
    May 8, 2004
    28
    Orange Beach, Al
    Mark G.
    Just bought 88.5 T/R and have about 1" clutch travel before clutch comes into play from floor. It seems like almost enough but not quite. No record of clutch replacement but I was "told" it was changed 6k ago. Who knows but not had a T/R in past and anxious to make sure all is well. Have burned clutches in other F cars and no experience with this. Any insight would be appreciated.
  2. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    Only two things to do:
    1) Make sure the hydraulic system is full, and bled properly
    2) Start saving for a new clutch
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    If the clutch bites too close to the floor, it's likely that the clutch itself is ok, but maybe some air in the hydraulics.
    When the clutch is worn, the bite will be higher and it may slip under load.
  4. pdavis
    pdavis Rookie
    Oct 31, 2003
    37
    Morristown New Jersey
    Preston
    I have a 1988.5 TR and I had the same symptom. I had the clutch checked and the slave cylinder rebuilt and it still engages much lower than my other cars (Porsche, Viper, etc.) I think that this may be quite normal. I am curious to hear what other TR owners have to say? PD
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Make double sure the pedal is not fouling on any carpets etc. There is a stop on the shaft, and it should be used.
    If the very upper part of the pedal stroke is lazy/spongy it may have some air in it.
  6. TR Mark
    TR Mark Rookie
    May 8, 2004
    28
    Orange Beach, Al
    Mark G.
    Many thanks to all replies , looking fwd to more replies too. Carpet is ok and I will have system bled. Again thanks
  7. khayes
    khayes Formula Junior
    Nov 1, 2003
    591
    Austin, TX
    Kelly Hayes
    The clutch begins to engage relatively early on my 86 TR. Probably 1 inch from the floor.
