TR dash removal | FerrariChat
TR dash removal
Discussion in 'Boxers/TR/M' started by ago car nut, Oct 9, 2017.
  1. ago car nut
    ago car nut F1 Veteran
    5,506
    Madison Ohio
    David A.
    Continue post on dash removal: photo1042 vacuum bolt removal. Also on the 8mm nut on speedo pod trim piece, I cut the washer in half so you don't have to completely remove the nut. Ok now remove knee pad guard on US. models. Remove carpeted lower speaker trim pieces, 4 hidden small phillips screws. There are eight verticle 13 mm nuts holding knee pad to dash. You remove speakers to gain acess to them. Now I believe you can remove 10 mm bolt holding top of console (fuel, clock oil temp gauge part). Undue wiring harness for fuel gauge etc. I labeled these. Lift console from rear and undue any thing holding it, forgot gearshift gate (2 screws). Fish the center heater control panel thru console if leaving connected. to be continued! ( last photo is one of 8 13 mm nuts holding knee guard. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. ago car nut
    5,506
    Madison Ohio
    David A.
    #3 ago car nut, Oct 9, 2017
    Sorry about the rambling. I'm better with a wrench than keyboard! I believe now we can remove the rest of dash. I removed steering wheel with special spaner I machined up, and need puller to remove steering wheel. There is a 3rd screw that holds the cover under steering column, (wrinkle piece under steering wheel). Remove radio, Undue bolts and nuts 10 mm, holding dash to car. 2 bolts in glove box, 2 nuts at top of dash in front of driver, and 3 bolts I believe in front of steering column. There are two 10 mm bolts vertical at each far end of dash, where knee pad was, at extreme ends. Loosen clamps for side defroster hoses. Carefully wiggle dash out. Now you see three clips with Phillips head screws holding top dash panel in. Cracked plastic and old foam. I reused dash cover leather, was good shape. I used 1/8" ABS plastic, glued new foam and stapled (short staples 5/32") defroster vents to ABS. New Italian black leather was replaced on speedo pod and left of pod. (had a trimmer do this). Took me about 3 hours to remove dash, not as bad as I expected. Just take your time. When I had dash apart, I pulled two new 10 foot heater hoses back to the engine. (30 year old originals) Top photo is steering wheel spanner. You can see how bad plastic was on top dash cover. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login )Connected new to old with fitting and pulled from engine bay. I have engine out. ( another post coming up).
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,545
    romano schwabel
    when I once removed my dashboard I not removed the stearing wheel. I let down the complete sterringwheel mechanism
  4. ago car nut
    5,506
    Madison Ohio
    David A.
    Here is photo of the 3rd screw holding the wrinkle cover under the steering column, Has a ground wire also. Other photo is of two 10 mm nuts and three 10 mm bolts holding dash to car. If you remove the steering wheel you can clean the switch contacts for the fog light flash stalk. Mine was oxidized. When the heater and A/C panel is out, you can clean those switch contacts also. Image Unavailable, Please Login Image Unavailable, Please Login
  5. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Hi David. This is one of my winter jobs along with whipping the heater matrix / fans out so thank you very much for posting up.
  6. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Thanks for the pics. My upper dash is light tan color as opposed to dark brown. Now I know exactly where the tab is to remove it and recover it to get rid of the reflection.
    Is that the only screw holding the dash top on (the half moon with the defroster vents)?
  7. ago car nut
    5,506
    Madison Ohio
    David A.
    There are 3 tabs holding the dash top on. Forum number three, the 4th photo is the middle tab. Kind of simple when you get things apart. You can see this is a hand made car and plenty of time was spent trimming the interior. I also replaced the old foam around the A/C center vent. I would like to know how to add arrows and circles to my photos? I could explain better.
