TR Differential Pressure switch...???? | FerrariChat
Discussion in '308/328' started by carguy, May 18, 2005.
  1. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,426
    Alabama (was Mich.)
    Jeff
    In my quest to get all the "bugs" out of my TR, I would appreciate if someone could tell me about the differential pressure switch, and it's associated plumbing. This is that little vacuum cannister with the wires connected to at the front/top area of the right rear inner fender. There is a vacuum hose coming from the right side intake plenum, that connects to a "T" fitting and then there are two short hoses from the "T" that go to the switch. The switch has 3 ports, but I only have two hoses plugged onto it....so one port is "open". I would like to verify this thing is hooked up properly and working. Any help is appreciated.....Thank You; Jeff
  2. Steve Magnusson
    26,904
    #2 Steve Magnusson, May 18, 2005
    Does this mean that you failed the cold-running "blip" test?
    Don't confuse the electro-valve controlling the valves on the air injection system with the differential pressure switch (even though it's all mounted in a single lump). I believe the figure on page 72 of the '89 or '91 TR US OM shows it correctly (and I'm going from memory so I'll correct anything I mangle later):
    The vacuum line from the 1/6 intake plenum is "T"ed into 2 streams -- one goes to the single fitting on the differential pressure switch and the other goes to electrovalve fitting #1 in the jpeg (the picture is from a different F application so the hose hook-ups are different) -- the end of the electro-valve that has two fittings. Another vacuum line runs from electrovalve fitting #2 (sticking up on the electro-valve) to the air injection system control valves, and the (single) fitting #3 on the other end of the electro-valve is open to atmosphere.
    Essentially all you need is that the fitting on the differential pressure switch is (always) connected to the 1/6 intake plenum vacuum.
