TR Door Lock Post/knobs | FerrariChat
Discussion in 'Boxers/TR/M' started by OptimusPrime, Jan 31, 2013.
  1. OptimusPrime
    OptimusPrime Formula Junior
    May 10, 2011
    291
    Florida
    Tom
    Hoping someone can help me find the door lock posts for a 88TR. So far all I can find is the posts with the rod attached as an assembly for a crazy price. Since I already put on the sound barrier and assembled the door, I don't want to replace the rod assembly but would rather press or bond one back on. I was hoping there was a source for the posts (black) that will work that someone has already figured out. They do not screw on & off...that is why I broke one :-(
    Thanks.
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Can you not (re)make that part yourself Tom ?
    Please show us a pic or diagram with corresponding number you are interested in ...
  3. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    #3 KENCO, Jan 31, 2013
  4. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Oh..........Sorry I just re-read and see you just want the black rubber piece.
  5. OptimusPrime
    May 10, 2011
    291
    Florida
    Tom
    Hi Mel,
    I thought about turning one on the lathe and was thinking about making a few out of polished stainless. Even though I own the company, the head tool maker kicked me out last time for not leaving the machine the way I found it and making a mess. I thought I did a good job of cleaning up..hmm.... I may have to sneak in at night. They tell me there is nothing worse than an Engineer that thinks he is a tool maker.
    I decided to keep original and was hoping there was a source. I think Kenco identified a low enough price at Eurospares and I could remove the metal pin. I also looked at some after market posts that I could bond on, but they all seem to have too big of a threadded ID.
  6. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    You can just use PC7 or JB Weld and that would fill up the void and hold well, positioning would be the key until it sets.
  7. OptimusPrime
    May 10, 2011
    291
    Florida
    Tom
    I'm on it..great plan, thanks.
  8. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Others have said the knob screws on the shaft but on my '88 I could not get them loose and feared I would split them or twist the rod. In the end I left them in place and pulled the door panel/card over the knob.
    $22.67 from ES is a good price for the knob and rod, though it says "to order" vs. "in stock" so there's a chance they are NLA.
  9. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    If you can find PC7 in your area I would use that, its thicker than JB and it wont tend to run down the shaft.
  10. OptimusPrime
    May 10, 2011
    291
    Florida
    Tom
    Yep, my 88TR post did not screw on so it broke on me trying to remove it. No threads but rod has swaged shaft that was either molded over or press fit over. As is always the case, wish I knew then what I know now I would have reached up and disconnected the green clip on the wire shaft.
  11. ferrari details
    12
    Have you tried Ferrparts?
    Scott
  12. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    A way to prevent the PC7 from running down the shaft is to use masking tape to build up the diameter of the rod/ shaft directly below the knob's final set position....Mark
  13. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    I thought this thread was about the posts on the starker plate.
    If your black plastic sleeve is broken/missing, I used a piece of thick heat shrink tubing. Works as factory and cost pennies.
