TR Drive Flange leak | FerrariChat
Discussion in '308/328' started by lear60man, Nov 27, 2004.
  1. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    I have some minor seepage on the drivers side driveshaft flange. Anyone have experience as to labor cost etc.?
    Thanks,
    Christian
  2. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    By flange leak, do you mean:
    1) The rubber boot, covering the CV joint?
    2) OR; The rubber seal holding the flange housing......that, to which the axle shaft bolts onto? This will leak along the side of the transmission cover, below the level of the axle shaft.
  3. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    The leak is coming from the inner most area of the drive shaft where it goes into the side of the transmission. So I guess the second description is the that is accurate. Fairly common problem?
  4. henryk
    Dec 9, 2003
    479
    Door County, WI
    I believe the problem is common enough............I replaced the seal, on my TR, about 2 years ago.
    The inner drive shaft has to be removed, and moved over, out of the way. There is a 17-19mm bolt, with a large washer, that has to be removed. The flange is then pryed out.......exposing the seal.
    The problem is that it is a very recessed area, once the flange comes off........and the shaft, from the trans sticks out. It is hard to get the old seal off and the new seal on.........I had to machine a seal installer. It can be done. When I did mine, I removed the whole axle shaft, to allow more room to work in. The seal costs about $30.
  5. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Thanks Henry. In other words, take it to a mechanic. I dont have the room to work on the car.
    Christian
  6. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Christian - Have oyu found a good mechanic in your area?
  7. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Jerry,
    I talked to the mechanic that did the 30K service and he knew about the seepage. It really is like a drip a week and I am being totally anal. He told me not to worry about it. I will probably use Blackhorse Automotive for anything that pops up. But then again Auto Gallery is just down the street.
    Christian
