TR Driver's seat cushion question. | FerrariChat
Discussion in 'Boxers/TR/M' started by James_Woods, May 3, 2007.
  1. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I had been looking at a Testa in St. Louis, MO this past week...dropped out because they wouldn't do a PPI without a deposit. Anyway, one of the issues was that the center cushion of the drivers seat had separated away from the door side bolster by about 1" or so. I have seen another Testarossa while shopping around that also had this problem...so it must be happening with some frequency.
    There is a picture in the Kansas/Missouri thread "PPI in St. Louis" that shows the issue - one of the local guys there was good enough to check out the car and took those shots.
    So - my question is - Has anybody else seen this, & How do you fix it?
  2. Kds
    Kds F1 World Champ
    No PPI without a deposit.....stupid eh ?
  3. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    And he lost a sale over it. You can read the whole ridiculous thing on the KS/MO locality section.
    Anyway, I have my sights set on an 86 with 22,000 miles. Norwood is doing the PPI even as we speak. If it happens, then I will bombard the Boxers/TR/M section with all kind of interior restoration questions.
    James
    PS - the 86 I am trying to buy is not the one with the seat issue, but it does kind of need a lot of little fit & finish things in the interior, and probably new carpets or a good cleanup. The exterior may be the very cleanest and best older Testarossa I have ever seen.
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    If I was looking at a car, any car and wanted to inspect it prior to purchasing it I would expect to pay for that service if I was unable to evaluate the car myself. If I buy a used house I have to pay to have it inspected if I choose to do so, so why would this be different? If I was selling my boxer I wouldnt lay out the dough for a PPI on the off chance some yoyo wanted my car, that could get very expensive if this was done for every tire kicker out there. I see nothing wrong with asking for some sort of compensation if the buyer insists on having a professional inspection performed.
  5. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Well, no sense in beating this to death again but I offered to pay for the PPI. The dealership, though, wanted me to put up a 2,000 dollar deposit and then also pay for the PPI. There was considerable thought from the local guys that you would never get you 2K back if it did not pass the PPI.
    Anyway, that's over with. I really was just wondering how this seat separation thing happens and what you can do about it if it should happen to your/my car.
  6. yellow jacket
    yellow jacket Formula Junior
    Feb 25, 2006
    294
    Modesto CA
    Charles Lunsford
    My seat is doing the same thing. How can it be fixed?
  7. Steve Magnusson
    26,781
    I'd say it's a fairly common thing to have happen -- the door sill is so wide that when doing almost anything in the interior (treating the leather, cleaning the inside of the windows, installing pedal covers, etc.) you wind up sitting on top of that outer bolster. I noticed mine was a little more deformed outward after having the seat belt recall performed, but not enough to worry about fixing/improving it yet so no experience with making a repair.
  8. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    Sitting on the outward boster is the problem. Over time the bolster will move away. My went so far as to actually break and fall down all the way. I removed the seat and bolster. There is a metal rectangular piece that holds the bolster on. It weakens and then breaks.......I believe it is out of aluminum.........this has been a while ago. I shaped a steel rectangular piece and rivetted it in place. Brought the seat back to about 80%.......worked well.
  9. rollsorferrari?
    rollsorferrari? F1 Veteran
    Jun 5, 2006
    9,984
    St. Louis
    Scott
    #9 rollsorferrari?, May 3, 2007
  10. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
    Both cushions detach from the seat frame with 6 or 7 small self tapping screws. The entire bolster is made of folded aluminium sheeting, with high density foam under a leather covering. The aluminium deforms with presure and weight over time and the parts that screw to the seat frame become distorted.
    It's quite simple to pull out the seat, toss it on it's side on a soft matt, then locate the screws holding each bolster.
    Then you will see what has been deformed and gently tap the aluminium back into the proper shape with a ball peen hammer. Speed nuts are used to secure the bolster to the frame and the self tappers screw into these. Many may be broken and require replacement. Available from all good auto parts stores. Make sure you get the right size as they do vary a lot from Jap to USA to Euro cars.
    Most Testa's suffer from this problem. Especially if previous owners was a bit on the chubby side!!
  11. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    The '86 did not have this problem (yet) but it is good to know that this is not the end of the world.
    Shows yet again that a little research and good faith on the part of the other dealer on the '87 would have gone a long way -
    We are finishing the inspection on the '86 this morning and I should know by the end of the day if I finally have my first Ferrari!
  12. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Another fun fact in 86 TR seats is the rubber straps strech out over time and it is easy to replace those strips with thin sheet metal. The pan will flex forward and back, it just won't let you fall into a hole behind a cross bar. Just pop rivit the metal (thin sheet like aluminium used on valleys when roofing a house) to the support bars. Works better than nylon straps or nylon cloth material. YMMV
    Jeff Pintler
    89 348tb, 86 TR
  13. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    After coming across this thread I got inspired to "tighten up" my side bolsters (both the bottom and side) on my 87 TR. Process was quite simple:
    1. Removed seat form vehicle
    2. Folded the back of seat forward, which gave me access to the one self tapping screw that holds the back panel in place.
    3. Once screw was removed I slid the panel up and out of the way, completely removed it and set aside.
    4. Pulled the 2 pins that hold the head rest in place and pulled the head rest completely off and also set it aside.
    5. Now the allen head screws that hold the bolster in place were exposed. One was about to fall out and the other was quite loose. Tightened them up and moved on to the bottom seat bolster.
    6. Same situation was found there also so just "persuaded" the metal mounting brackets back to their original locations and tightened everything up.
    7. Reversed the above steps to re-assembled the seat........
    And low and behold the seat is all nice tight and ready to support my oversized ass once again for another year.
    Lesson learned? Yeah, once a year take the seat(s) out and re-tighten these attachment points before they get fatigued from being loose and break............
    Kerry
  14. Scaledetails
    Scaledetails F1 Rookie
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    James,
    If you are looking at a car from Schmidt, DO NOT BUY IT!!! He sells nothing but junk, or should I say, beautiful cars from a distance and when you get up close, you see all the problems. There has been several threads here about that dealer and his Testarossas. Absolutely do not give him any money unless it is refundable upon a complete PPI. BUYER BEWARE, I would hate for you to jump into a nightmare like many others have, specially with a Testarossa.
