Tr engine mounts help needed | FerrariChat
Discussion in 'Boxers/TR/M' started by ang308, Feb 6, 2019.
  1. ang308
    ang308 Formula Junior
    361
    Stamford, CT
    Billy
    So after 3 months of receiving my fixed tranny (thanks wade) I’m finally getting to putting the car back together again. But after 6 months of taking everything apart and foolishly not taking pictures of the engine mounts I forgot how they went together. Where does that big washer go? On top, in between frame and mount, or on the bottom with the nut? Sorry for awful photos but I’m talking about the washer/spacer in my hand
  2. ang308
    361
    Stamford, CT
    Billy
    I have that diagram and unfortunately it doesn’t help me. I know about the washer that goes to the bolt head. The washer that is in my hand is either a spaced that goes between the mount and the subframe or on the bottom. I’m guessing it’s number 56 on the diagram I just don’t where it goes that is all. I’m almost remembering that it went between subframe and mount but definitely not sure
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,921
    romano schwabel
    gradulation to your now rebuilt gearbox. I remember the big problem you had :( so what parts wade replaced all?
    no. 56 is not completely round, this what you have in hand is no.57
  4. ang308
    361
    Stamford, CT
    Billy
    Thank you. Just the photo I needed. But I do see a spacer of some sort between subframe and engine mount or am i seeing things?
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    From bottom up:
    You see the frame, then item #56, then the black rubber bush, then the #33 cone, then the black engine mount.
    Don’t forget some lithium on your bolt to inhibit corrosion.
    turbo-joe likes this.
  6. ang308
    361
    Stamford, CT
    Billy
    That’s exactly what I needed guys thank you so much. For some reason I don’t have the big washer that goes below the bolt head they’re smaller and I kind of remembered there was a spacer between frame and mount. That’s why I love this sight.
  7. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Agreed.... I ‘assumed’ it was a standard flat washer
    Looks like a good candidate for refinishing(?)
  9. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Agree with that Vincenzo!
