TR Engine type/variations/hp | FerrariChat
Discussion in 'Boxers/TR/M' started by Basal Skull, Dec 31, 2021.
  1. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    (Couple of questions at the end)
    Type
    F113A Euro non cat 9.31 comp k-jet 390 hp
    F113A040 Us/Japan cat 8.81 comp ke-jet 380 hp anti evap emissions and secondary air pump
    F113A046 Swiss no-cat 8.81 comp ke-jet air injection
    F113B euro 1986 cat (since 1989) 8.81 comp ke-jet air injection
    F113B046 Swiss cat 8.81 comp ke-jet evap emissions and secondary air pump
    ? So there is this engine, mentioned occasionally but not well documented. I assume: F113B069 Middle East 8.81 comp ke-jet no-cat no-air pump/injection
    Is the euro F113B euro ke-jet (cat/air injection) also 390hp?
    If so is the F113B069 ke-jet (no-cat/no-air pump/injection) possibly the most powerful -hp wise theoretically?
    • just thinking, not that it makes any practical difference.
    Thx
  2. Rifledriver
    37,288
    The only horsepower related differences are slight cam timing with the same cams, slight ignition advance adjusted internally on the same ignition unit and a small compression change. According to the parts books the low compression pistons are US only. Make me think all other versions are 390.
    Such a small difference it would not surprise me if production tolerances made as much difference as any changes the factory made. And such a small difference would need to be measured by machine.
  3. Basal Skull
    Oct 26, 2010
    427
    Vancouver BC
    Makes sense, low compression pistons being US only is new info for me from what I've read. Appreciate you clearing that up. Thank you for the input!
