TR First drive impressions and questions! | Page 2 | FerrariChat
Discussion in '308/328' started by kerrywittig, Mar 15, 2006.
  1. kx5fast
    kx5fast Karting
    Jul 4, 2005
    161
    RP
    Just to keep this question alive, I just returned from an extended drive (512TR) and reached 100, 110 and 120 for at least 30 seconds at each speed. No buffetting at all in any of the speed ranges mentioned (in fact the car seemed to get somewhat quieter, and certainly it was well mannered).
    I do not think the aero's on the 512TR are dramatically different than its predecessor, but I could be wrong.
    Rod
  2. Rifledriver
    37,288
    Been working on them since 85 and have had one for a few years. Unless something is wrong there is no buffeting and until you are very close to top speed instability and lightness in the steering are not a problem. At near top speed they did have a small amount of lift (all the prior cars had a lot of lift. Up until its replacement the TR was the best aero car they had ever built. It was the first Ferrari street car that was designed in the wind tunnel) and there is some buffeting like noise generated by the rear view mirror(s).
    The mirror noise was a common complaint.
    As I said before at the 125 range it should be a very serene ride. Mine is.
  3. F1Ace
    F1Ace F1 Rookie
    Mar 15, 2004
    2,980
    Wes
    Thanks guys for clearing this up, not only for me but I'm sure for "Mr. Attention Grabber"--Kerry. ;)
  4. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    OK......Here is the outcome, or should I say the "buffeting" cure!
    WOW...........I have a totally different TR!
    I had the tires and wheels load balanced on some new state of the art Hunter balancer, by people who understood what the hell I was trying to achieve. The proper term for the balancing I believe is "load balancing". What takes place is the tire and wheel are spun and the diameter of the tire and wheel are plotted to determine the "high/low portion of the wheel/tire combination. (This is done while a pre-determined load is applied to the spinning tire). In this case 800 lbs to the front tires and 1000 to the rear tires. These figures were computed, figuring that the TR weighs 3600 lbs. and that the weight distribution at rest is approx. 1600 lbs. on the front and 2000 at the rear. After this the tire bead is broken from the wheel and the low part of the wheel is lined up with the high spot of the tire. Trust me the wheels, as well as the tires are not "perfectly" round. The measurement is in lbs.. I guess an easy way of explaining is if you look at the wheel and/or tire as being like a cam......the "out of roundness" being that it appears as a "lobe" on a cam and where that high spot is, exerts pressure, or where it is low it releases pressure which is computed and then you align the high with the low spot. Have I confused everyone yet? The actual measurements were as follows;
    Drivers side front was 33 lbs. out of round. What you are trying to achieve is a weight below 25 lbs. So after re-aligning the wheel and tire........15 lbs. was achieved. The passenger front was well within the 25 lbs. or less. I was told by the technician that the driver would be hard pressed to be able to feel anything under 25 lbs.. The driver rear was fine at 13 lbs. and then the biggy was the passenger side rear at 44 lbs.. It was corrected to 24 lbs. and we put all four wheels and tires back on the TR. But first I opted for the tires to be purged of air and nitrogen was pumped into the tires at 34 PSI front/ 36 PSI rear. Nitrogen will not expand, nor contract, (raising and lowering tire pressures as they heat up or cool......always at the pressure prescribed......no fluctuation). Well first realize that I had two tire/wheel combinations that were whacked at a diagonal from each other, ie. driver front/passenger rear.
    What an amazing difference .........immediately.........slow speeds, at highway speeds and as of this date up to 150 MPH....smooth as glass, rock solid on the road. Absolutely astonishing the difference...the TR drives completely different, in a very positive fashion!
    I am very pleased.......... balancing and nitrogen came to a very inexpensive $80 total for four tire/wheel combinations. And to top it off I was invited back, for 2 more complete procedures at NO charge to correct the balances even further as the tires and wheels "settle in"...........I am very happy with the results and suggest this to any and all F-car owners. Hell I have an appointment on Friday to get all six tires and wheels done on my Chevy dually, it's that amazing!
    Kerry ...the happy TR driver...........now!!
  5. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,427
    Alabama (was Mich.)
    Jeff
    Wow that's amazing and very good to hear! And the cost was very reasonable in my opinion. Filling the tires with nitrogen is an excellent idea, but when the pressure bleeds down over time, do you use air or more nitrogen to get the pressure back up to spec?
    I've had that load balancing done on the Audi A8 and the ride was like glass. For an everyday beater it's not necessary, but fior a high performance car maybe it should be standard procedure.
  6. kx5fast
    kx5fast Karting
    Jul 4, 2005
    161
    RP
    Now that is very interesting. If I were to approach a local tire shop, what are the code words to ask (like, can you do load testing form maximum balance distribution on all four corners?) I am afraid if I ask the 19 year old tire jockey his eyes may glaze over. I think I would like a looksee at the wheel balancing on my car, although it is smooth, perhaps it could be smoother?
    I will cut and paste your description and take it to the local tire jocks, but my real question is does this take a specialty shop to load test the tires?
    Rod
  7. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    The shop that did mine was suggested to me by the "big" tire store in town........A little out of the way place.
    Wait I have and idea.............I'll Be Back......................
  8. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Well here ya go.................this is a link to the manufacturer of the machine that did my tires and wheels. There is a tab in the top right corner to locate a machine in your area! How's that for service..............
    http://www.gsp9700.com
    Kerry
  9. Hessian
    Hessian Formula Junior
    Jan 22, 2005
    555
    Charlottesville, VA
    Jonathan S.
    I'm glad you got things squared away, and it sounds like you did well with the load ballancing, but the above statement is simply incorrect. Nitrogen will be far less likely to chemically react with your tire or your wheel, but it will most certainly expand and contract just like air (which is 78% nitrogen) will. At the temperatures and pressures that are present in your tire the nitrogen's behavior will be well described by the ideal gas law.
  10. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Just repeating what I was told (by the saleman).............DOH! Well then I have $10 worth of nitrogen in my tires and I am proud to be nitrogen only inflated.......there I justified it to myself, I feel better.........LOL.......Kerry
