tr fuel regulator required | FerrariChat
Discussion in 'Boxers/TR/M' started by MAFIOSA, Oct 3, 2014.
  1. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    #1 MAFIOSA, Oct 3, 2014
    are the regulator similar to mercedes.benz items
    my ones leaking,so any help would be nice
    yes the small balck regulators ,i require urgently
    thank you
  2. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    FUEL REGULATOR SUIT TR
    ANY HELP PLEASE
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,526
    romano schwabel
    the TR koenig competition I have here had been inside regulators from the mercedes
    bosch part number 2 437 020 008
    koenig told me that those deliver a little more fuel.
    so when you change and the original regulators have a different bosch part number then you may change both, not only the leaking one.
    but when it is leaking you may change normaly only the O-rings, or is the regulator broken?
  4. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
  5. Otus
    Otus Rookie
    Jul 23, 2013
    25
    Finland
    Ville
    In the picture you have EHA (Electo-Hydraulic-Actuator), not fuel pressure regulator.
    Which is right part for you?
    Between the fuel distributor and EHA there are two small o-rings which are easy to replace.
  6. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    oh :(
    you are right otus
    I was thinking about the EHA because of changing the O-rings but have writen regulator.
    so never write here something when you had a long party the night before :)
  7. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    i think the fuel is leaking from the o ring,s ,however my mechanic has said it is the (black regulator) and that its seeping from a faulty part,by way of leaking internal ,i don,t know what to think,
    thank,s to all of you here ,for your imput
    kindly
  8. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    both are leaking
  9. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    then you or your mechanic only may change the 2 O-rings each side
  10. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Romano, no party last night?
  11. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    :) no :(
  12. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    #12 MAFIOSA, Oct 6, 2014
    Do i purchase the part 2437 02 0008 or just change the o rings mmmmm
  13. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    where can i find this bosch part available
  14. turbo-joe
    Apr 6, 2008
    9,526
    romano schwabel
    the bosch part number changed to F 026 T03 009 and the part description is: fuel pressure regulator
    it is still in the price list with around 315 €. but none of my supplier has it in stock here in germany.
    why you want to buy new one? is this here broken?
  15. slownrusty
    slownrusty Formula Junior
    Oct 1, 2014
    395
    Houston
    Slow Rusty
    That EHA looks identical to the Bosch item that I replaced on my '91 560SEC Benz, mine was dribbling fuel past the two O-rings as well. This Bosch unit can be adjusted to richen or lean the mixture:
    I paid $150 and bought it brand new from the MB dealer.
  16. Otus
    Otus Rookie
    Jul 23, 2013
    25
    Finland
    Ville
  17. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    I HAVE SENT A MESSAGE TO CIS flow tech for a new replacement ,i will try to fit o-rings first ,its a lot of trouble to remove the left side actuator ,r/s was easy.
    thank you all, so far for your help here.
