TR fuel tank removal | FerrariChat
Discussion in 'Boxers/TR/M' started by Shinny, Sep 11, 2013.
  1. Shinny
    Shinny Rookie
    Jul 5, 2009
    35
    Ontario, Canada
    Dave Schinbeckler
    The left fuel tank on my '88 TR is leaking around the inboard strap. Is the tank aluminum or steel? Can't tell from the manual. Anyone taken one of these out?
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Ferraristi,
    Before you start removing things, remove the lower panels covering the fuel tanks. There you will see a balance hose going between the tanks and 2 rubber hoses going to two fuel pumps. If fuel is leaking from there, it will run down and travel along the strap.
    Check the hoses first.
    Also, there are some breather fuel hoses on the rear of the tanks just in front of the engine. Check and see if those are alright. Those are usually the culprits as they don't usually get changed with an engine out service.
    Shamile
    Freeze...Miami Vice!
  3. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Tanks are aluminium.
  4. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Shamile is absolutely right. I was quoted $1200 to remove the tanks in an attempt to find the "leak". Turned out to be the breather hose from the fuel regulator.
    Check this out
    http://www.ferrarichat.com/forum/boxers-tr-m/407638-proud-new-testarossa-owner-2.html
  5. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,545
    romano schwabel
    until now I never had a leaking fuel tank, except when you had an accident.
    so check the hoses all before doing a lot of work for nothing
  6. Racing-Baker
    Racing-Baker Karting
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    Could somebody tell me where i can locate the fuel tank Sensor?
  7. turbo-joe
    Apr 6, 2008
    9,545
    romano schwabel
    right tank at the bottom. only reachable after removing the aluminum plate
