TR glovebox will not open........... | FerrariChat
Discussion in 'Technical Q&A' started by Kds, Aug 22, 2006.
  1. Kds
    Kds F1 World Champ
    The switch for opening the glovebox on my 1990 TR works, and you can hear the actuator inside the glovebox working, but the door of the glovebox will not open.
    TIA for any and all suggestions.............
  2. Steve Magnusson
    26,931
    Do you mean that even if you insert a credit card at the top seam and give it a little helping "tug" at the right moment that it won't open?
  3. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Try giving it a little pull from the top. Mine sticks a little and this helps.
  4. Kds
    Kds F1 World Champ
    I haven't tried inserting a c/c yet.....but did push and tug on it......maybe not hard enough though as I didn't want to break something.
    I'll let you know what happens. Thanks !!
  5. Rifledriver
    37,288
    Around the opening the leather sticks to itself. If at the same time you hold down the sw, you whack it with the side of your fist it will open. Tools and finger nails often slip and scratch the leather.
    Opening the glove box door on a TR is not unlike the AM oil pressure gauge thump required on Veglia oil pressure gauges to wake them up on the early cars.
  6. tbakowsky
    Sep 18, 2002
    20,035
    The Cold North
    Tom
    There is also an emergency release cable buried under the right side of the dash, just above the speaker box for just such an occation. Dig around in that area and you will find it. Most times I have found the the latch on the glovebox door is out of wack and the solinoid can't pull the catch back far enough to realse the door. A good healthy tug on the release cable should open her up.
  7. Rifledriver
    37,288
    The leather sticks even when the back up cable is pulled.
  8. 90TR
    90TR Formula Junior
    Nov 23, 2005
    274
    Celebration, FL
    Bill
    Yup. My glove-box needs a little thump every once in a while. I adjusted the latch; but seems to be just the leather hanging up.
    Bill
  9. Kds
    Kds F1 World Champ
    Well.............I got in there and just f-in wailed on it............and guess what.......ba-bing !!
    Works like it should.......thanks guys.......!!
