TR Leaking Fuel Pump & Hose Replacements | FerrariChat
Discussion in 'Boxers/TR/M' started by 1TRICK6, Jun 2, 2016.
  1. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    #1 1TRICK6, Jun 2, 2016
    One of my fuel pumps is buzzing pretty good and now I discovered it's leaking from the bottom seam under the positive terminal. The other fuel pump is buzzing a little too.
    Does the buzzing mean it's going out too although not leaking?
    Should I replace both of them.
    Replace with original Bosch pump #69532 or any other alternatives?
    Thinking about changing my fuel lines while I'm at it since it wasn't done during engine out service last year (they said they look good, they must of had x-ray vision). PM me if you want to know where not to go in Orange County for service.
    I attached a pic of my fuel hose (yellow) connecting the two gas tanks, doesn't look original nor fit too good.
    Any suggestion on getting fuel hoses between the two tanks and inlet hose to fuel pumps (what sizes) besides Scuderia Raparte, they only sell a kit which also includes the two hoses attached to the fuel filler pipe to the top of the gas tank, which I might not need.
    Thanks in advance for any suggestions.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    this small hose connecting the two tanks is never original. looks more like a hose for sprinkling the garden or an air pressure hose.
    you may use a normal rubber fuel resistent hose or if you get a silicone hose, but be carefull: also this silicon hose has to be fuel resistent - don´t take a water hose ! ! !
    if some other hoses will leak then just replace them all. so only one time work and you are on the safe side
  3. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
  4. stardoc
    stardoc Formula Junior
    May 5, 2005
    669
    The big oven
    K RA
    Funny, I've started to notice the buzzing sound and exhaust back fire. Taking the car in tomorrow for the service.
  5. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,704
    wisconsin/chicago
    bo
  6. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    I replaced both of mine last year with these ones. The old ones were working ok, but I noticed the fuel pump relays were getting very hot. They are over 30 years old, even though only 19k miles. No issues with new ones and fuel pump relays don't get too hot anymore.
  7. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    you only changed the fuel pumps or also the relais?
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    The hose you have fitted is braided airline hose, you are lucky it has not split as it goes yellow and solid with age. Definetly not for petrol
  9. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    The original hose was the fuzzy type hose used on CIS German cars. Use fuel hose rated for modern ethanol fuel.
  10. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    I just changed the fuel pumps.
