TR overall gear ratios for euro, CH, and US versions | FerrariChat
Discussion in 'Boxers/TR/M' started by Steve Magnusson, Feb 3, 2023.
  1. Steve Magnusson
    26,826
    Since I had made an excel file to calculate the overall drive ratios for each gear of the various versions of 308QV, I thought I could easily just change the various teeth numbers and get similar results for euro, CH, and US version TRs. I was wrong ;). However, I learned a lot about the different TR versions and how each version had changed gear-wise over the years:
    1. I was surprised to find that 1984 to about 1990 euro TR and 1985 to somewhere in mid-1988 US TR have identical gear ratios (these are the values shown in the TR WSM on page E14, but they mangled their own “final reduction ratio” calculation a little).
    2. Somewhere circa 1990, the euro TR had a very slight change to the 1st and 2nd gear sets and split into two separate types with different transfer gears: “without catalyst” that retained the 27/29 transfer gears, and the “with catalyst” (I think this might be the “CAT” version mentioned in the TR SPC) with 26/27 transfer gears (making it very much like the early CH version).
    3. The CH version is a different beast, but it follows the same trend as 328 CH where, by using a less reducing transfer gear set of 26/27, every gear of the 1985-1987 CH version is taller than the 1984-90 euro version (where I’d guess that Ferrari assumed that you be in one gear lower than normal in hilly/tight terrain so making that lower gear have a taller gear ratio helps limit engine over-revving and noise). For the 1988 CH TR, the corresponding OM indicates that they changed the diff ratio to a lower 17/61 value which lowers all of the gear ratios (but I am a little suspicious if this was a typo as the OM table of the final drive ratios for 1988 CH version TR was not changed from the 1985-87 CH version TR OMs).
    4. On the US TR, somewhere in Model Year 1988, they changed the transfer gear set from 27/29 to 27/30 (the 480/87 TR OM shows that 1988 Model Year US version TR can have either 27/29 transfer gears or 27/30 transfer gears). My guess would be this roughly corresponded to the change from single-bolt wheels to the 5-lugbolt wheels, but the SN switchovers for both changes in the TR SPC don’t match up exactly (5-lug wheels starting at SN 75997 and the transfer gear change starting at SN 76474).
    Maybe what surprises me most is that I can’t recall a single time that these differences in gear ratios between the TR versions, or within the same TR version, has ever come up here for discussion. Maybe the greater power and torque of the TR engine just makes it a non-issue. Here are the results for each version TR:
  2. 71veedub
    71veedub Formula Junior
    May 31, 2006
    339
    Boston/North Shore
    Greg
    Nice work Steve! Did you not have data for the 89-91 CH TRs?
    I've been curious how my CH 512TR gear ratios differ from other 512TR variants, as the guy I purchased through had said the 3rd gear ratio at least was different. I can post the data from my OM if you don't have it.
  3. Steve Magnusson
    26,826
    You're giving me homework! I don't have any TR CH OM later than the one for the 1988 year. I've got three euro 512TR OMs (dated 91, 92, and 93, but they aren't clear about what model years they apply to) and three US 512TR OMs (dated 91 for 92 MY, 92 for 93 MY, and 93 for for 94 MY). I've got no CH 512TR OMs -- so please post any 512TR CH OM gear/gear ratio/# of teeth information that you have.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    thank you steve for this overview :)
    when I was rebuilding 2 gearboxes for my competition I noticed only 1st gear and also 2nd gear has different ratios, but not remember what year. also the size of the teeth are different even with the same ratio.
    I once asked here long ago about this and brian only wished me "good luck" in finding out. during I checked later I have been lucky because found out a lot of things but for me not important so much so I not have written down.
    nevertheless you can change in all 512 BB, BBi and TR family gearboxes all gear pairs, but never only single ones except there is the same parts number on and the same manufcaturer. but even then they could have been produced on 2 different machines. so when you do this job always check the pattern. I think only a few from us here are doing gearboxes and those for sure know this all.
  5. Rifledriver
    37,105
    The different teeth is due to a change in gear cutting technology changes by the gear supplier mid production. It used to drive us crazy getting the correct gears when rebuilding BB transmissions. There were many problems sorting out correct part numbers. Something that looked correct would when installed lock up the transmission due to different tooth profile. We found ourselves a few times replacing many gears and sometimes shafts to get compatible parts when only one gear was needed. I remember one in a BBi I had to take back out of the car and all apart because 3-4 syncro hub spline major diameter was changed by 1 or 2 mm and under high torque it slipped on the shaft. Made a horrible noise too. Fit perfectly, just had too little spline engagement.
    turbo-joe and 71veedub like this.
  6. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    only 1 gear or 1 gearset? under gearset I understand 2 gears produced on the same machine.
    normaly you always replace a complete set
  7. Rifledriver
    37,105
    No such thing in a BB or TR as a gear set. The mating gear in every case is either a cluster gear or shaft. So in the case of 4/5 you need to replace 4th, 5th and the cluster. If you can get them. In the case of 1-2-3-R now you need a gear and a shaft and in your world now you also need every other gear for that shaft......if you can get them. Then you have mismatched splines so you are buying more gears and syncro hubs.
    No sir, if I can get the one correct gear, its going in. Done it dozens of times. Its not a quiet car. A small gear noise is never heard.
    Besides how many gear hobs do you think even exist for TR/BB gears? One per gear design would be my guess so in reality every given gear is an exact match for its parts book mate in every case.
  8. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    #8 turbo-joe, Feb 4, 2023
    modena in australia is manufacturing those gears. a while ago a member here at F-chat ordered from them 1st and 2nd gear set and I rebuilt this gearbox and all was matching fine. it was from a TR.
    what you understand under cluster? cannot find any translation. you mean the roller race?
  9. Rifledriver
    37,105
    I have some experience with their gears and will in the future avoid them if at all possible. Some of the other products I am quite happy with but not the gears.
  10. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    oh? thank you for this info brian.
    could you please explain to me what you undertsand under "cluster"? or a parts number?
  11. 71veedub
    May 31, 2006
    339
    Boston/North Shore
    Greg
    Hi Steve, don't feel obligated but here is the info from my OM if you are interested.. Swiss car #97504, assembly #14514 (somehow they forgot to attach that plate), production 1993-06-24 thru 07-14. The last page of the OM says "Cat. 790/93 Codice 95990155". I'm surprised I don't see anywhere in the OM which indicates the market as CH.. but this is the original OM. I think the "model year" concept is a US only thing btw.
    Idle gear ratio: 27/29
    Gear ratios:
    1 35:12 = 2.916
    2 32:17 = 1.882
    3 27:19 = 1.421
    4 25:23 = 1.087
    5 22:27 = 0.815
    R 34:14 = 2.428
    Bevel gear ratio: 14/45
    Engine revs final reduction ratio/wheel revs:
    1 10.069
    2 6.498
    3 4.906
    4 3.752
    5 2.813
    R 8.384
    I find it easiest to think of the corresponding speed at some fixed RPM; if I've calculated correctly, and assuming 798 wheel revs/mile (tirerack.com), mph = RPM * 60 / 798 / X, where X is the engine to rear wheel ratio just above. For 3000 RPM and 7250 RPM I get:
    RPM: 3000 7250
    1 22.4 54.1 mph
    2 34.7 83.9
    3 46.0 111.1
    4 60.1 145.3
    5 80.2 193.8
    R 26.9 65.0
  12. Steve Magnusson
    26,826
    #12 Steve Magnusson, Feb 5, 2023
    Greg -- Even though your CH car came with the 790/93 OM, it does not mean that the 790/93 OM is for a CH version 512TR, and Ferrari is pretty good about labeling the OMs when they are not for a standard (euro) version. I'm 99.9% sure that the 790/93 OM is for a euro 512TR as the pictures of the transfer (idle) gears at Maranello Classic Parts show that the CH 512TR transfer gears are 26/27 (which is identical to all the other CH version models) and the euro 512TR transfer gears are 27/29. The 512TR SPC also shows that there are no different CH (nor US) gear sets and no different ring and pinion for a CH (nor US) 512TR. Consequently, I'll do the CH version 512TR table with:
    transfer gears = 26/27
    gear sets = same as euro
    ring & pinion = same as euro
    And the US version seems to be:
    transfer gears 27/30
    but I'll give everything one more careful look, and then post the euro/CH/US 512TR table in a day or two.
    Have you actually decoded your VIN at red-headed.com to confirm that it is a CH version? (Sometimes a euro version that gets sold into Switzerland and then gets sold to the US can get the moniker of being a "Swiss" car when it really isn't.)
  13. 71veedub
    May 31, 2006
    339
    Boston/North Shore
    Greg
    Hi Steve, interesting, I had noticed that the data I posted was the same as the Euro 90-91 TR without catalyst data you posted (with the exception of reverse ratio).
    Where would the OM be labeled CH? Mine has a stick-on label for Sportgarage F. Leirer (St. Gallen, CH dealer) on the cover.
    I'm quite certain it is a Swiss car: I bought it from the guy who sold it new; the warranty card shows model "512 TR CH" with the 8th digit of the VIN "S", and stamped by Garage Foitek (Zurich, CH dealer) with his signature.
  14. Steve Magnusson
    26,826
    Agree that it's a CH version if the 8th digit of the VIN stamped on the car is "S" (although you haven't stated that directly). The Swiss Dealer adding a stick-on label to a euro manual is something they would do if there was no CH manual available (and that may be the case as the OM file set from Ferrari doesn't include a CH 512TR OM). Also, sometimes Ferrari just added a small single/few page insert to an older/different OM and maybe that got lost (my 1991 US TR came with a 1989 US TR OM with an insert titled "Changes for M.Y. 1991). The different versions for the OM (from that era) are usually indicated on the title page of the OM like these examples for the TR (the "blank" one on the left is a euro version):
    But no matter -- I think the 512TR transfer gear photos from Maranello Classic Parts and the 512TR SPC information showing that no special CH or US gear sets nor different CH or US diff gears is pretty strong evidence, and will proceed on that basis. Although speedometers and tachometers aren't super-precise, your CH 512TR should have a low RPM to go 60mph vs a euro 512TR and especially lower vs a US 512TR.
  15. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Are the Boxer gear sets the same as the early euro or USA TR?
  16. Steve Magnusson
    26,826
    No, first blush is that the Boxers are more like the later US TR because the Boxer transfer gear ratio is 27/30. My guess would be that the goal on the early TRs was maximum top speed (and 4-valve TR had a little more power) so they went to 27/29 on the transfer gears on the early euro TR and the early US TR. There are some gear differences, too, between BB512 and BB512i, with 1st gear on a BBi being lower than a BB, and 2nd gear on a BBi being a small bit lower than a BB (3, 4, and 5 seem the same, but they completely butchered the overall reverse ratio entry for a BB512i in the OM as being an impossible 1:0.418) . Let me get the 512TR stuff done and then I'll have a closer look at the Boxers, but let me add that it's often (on all models) like the F engineers calculator was sometimes broken, or they mangled a hand calculation, or sometimes things got mis-transcibed as often they'll give the exact number of teeth yet their own corresponding calculation for that tooth ratio is off in the 2nd or 3rd decimal place by a small amount greater than just a rounding error.
    71veedub likes this.
  17. 71veedub
    May 31, 2006
    339
    Boston/North Shore
    Greg
    Hi Steve @Steve Magnusson yes the 8th digit of the VIN is 'S' in the various places it appears on the car in addition to the warranty manual.
    But I'm most intrigued by the OM photos you posted - I had been assuming my "Manuale tecnico" was what you were referring to as the owner's manual, but maybe I should have a separate owner's manual as well? Or the manuals for TR vs 512TR used different names?
    So if you think the only difference in the 512TR gearing is:
    CH transfer gears = 26/27
    US transfer gears = 27/30
    Euro transfer gears = 27/29
    then the difference between US and CH at 3000 RPM would be about 77.5 vs 83 mph in 5th.
    Nowhere close to as tall as my 928 where that RPM is ~100mph in 5th.
  18. Steve Magnusson
    26,826
    No, what you have (790/93) is what we typically call the "Owners Manual" here even though Ferrari changed the name (and the form factor) to "Technical Manual" on the 512TR.
    I don't know 928, but it sounds like they made the trade-off that many auto manufacturers make where the top gear is very tall to get better MPG in that top gear, but the engine really doesn't have enough power to get to redline in that top gear -- if it could, you'd be going 200 mph in your 928 at the ~6K RPM engine redline ;). Since Porsche's claimed top speed for the 928 is more like 140 mph, it probably does that in 4th gear. Many modern Corvettes are like this, too, where the upper gears are so tall that the maximum speed is achieved in 1 or even 2 gears below the top gear.
  19. 71veedub
    May 31, 2006
    339
    Boston/North Shore
    Greg
    Oh glad to hear I'm not missing something.. thank you. Still a very new owner, car just arrived end of November and it's been winter, and really only got a couple short drives as there are a few items to sort out (intermittent slow down on left, cooling fans).
    My 928 is a 1988 S4 (4th generation) so top speed is claimed 168 IIRC, but you are correct it will never reach redline in 5th. All the gears are quite tall, redline in 1st is faster than the 512TR despite a lower redline.
  20. George Vosburgh
    George Vosburgh F1 Rookie
    Steve, do you know what the reason is for these differences in the gear ratios? What were they thinking??
  21. Steve Magnusson
    26,826
    See this thread where I posted the 512TR overall drive ratios with those different transfer gears (I stated the reasons I think they made those transfer gears changes there):
    https://www.ferrarichat.com/forum/threads/512tr-overall-gear-ratios-for-euro-ch-and-us-versions.672830/
    George Vosburgh likes this.
  22. Steve Magnusson
    26,826
    turbo-joe likes this.
