TR seatbelt drive motor inop | FerrariChat
Discussion in 'Technical Q&A' started by wmcalister, May 28, 2016.
  1. wmcalister
    wmcalister Rookie
    Sep 22, 2001
    37
    Where is the drive module for the drivers side seatbelt located on a 90 TR? Is there a fuse associated with it? One day when opening the door the seatbelt motor did not operate.
  2. Steve Magnusson
    26,826
    No fuse. The seat belt ECUs are mounted to the backside of the lower center tunnel covers. Has your TR had the official recall done?
  3. wmcalister
    wmcalister Rookie
    Sep 22, 2001
    37
    Yes it was done years ago.
  4. Steve Magnusson
    26,826
    #4 Steve Magnusson, May 28, 2016
    One thing you can try if everything else seems OKish (and not obviously damaged/bound-up/mangled) is disconnecting the battery shut-off switch for a few minutes -- IME, once those ECUs detect a fault, they give up trying/retrying until "reset". If no joy, then you are left with swapping the two ECUs to see if the trouble moves to the other side or not.
  5. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Alternatively, ask your local Ferrari Dealership if they are willing to fix it free of charge. This is after all a safety item. I had mine repaired after the recall.
  6. wmcalister
    wmcalister Rookie
    Sep 22, 2001
    37
    Where is the battery shut off switch? I was not aware of one.
  7. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    big round switch above the battery door
