TR smells a little "rich" | FerrariChat
Discussion in 'Technical Q&A' started by Capone, May 18, 2006.
  1. Capone
    Capone Karting
    Mar 29, 2005
    235
    Midwest
    Hrm, parked the car in my garage last night after a 30 minute drive adn I noticed a strong smell coming from it. Doesn't really smell like gas but it is a very strong, similar odor. Any ideas where to start looking or what to do?
  2. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    676
    Charlotte NC
    Russell
    Don't smoke while looking !!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Russell
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,574
    The Brickyard
    The Bad Guy
    You may want to see if your cats are still good. If the honeycomb is burned out then they aren't burning off the unburnt fuel in the exhaust, so that could be why your getting a rich smell.
  4. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,176
    Mount Isa, Australia
    Pap
    Maybe check all fuel hose clamps?? Maybe have fuel weeping from a loose clamp or something silly as such?? Hard to pick up the smell from 10,00km in Australia. :) Maybe if i had the nose of a dashound.... :D
  5. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    I have my TR in Norwoods for a strong gas smell that I could not track down nor could James he thinks the hose from the gas filler neck to the tank has deterioated and the fumes are weeping through the hose no sign of fuel anywhere and the smell is worse when the car is closed in the garage.
    Martin
  6. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    antifreeze has an unusual smell and sometimes wont leak enough to be visible on the ground.oil seeping onto exhaust.fuel cap .ever tried to miss a plastic shopping bag.they are like magnets and always like adhering themselves to exhausts in a nanosecond.hot smell/brakes/ h/brake oops.evaporator pipe off.cv boot.check your fuel cans in the garage. wake up wake up i think you were having a bad dream.Sorry ------- if it smells like petrol 10 times out of 10 it is . crank car for a split second /look at fuel lines etc.weeping is usually more visible when hoses are cold.dont smoke in the garage anymore. Tony
  7. Turb0flat4
    Turb0flat4 Formula 3
    Mar 7, 2004
    1,244
    Singapore
    RND
    I don't drive a Ferrari, but I can tell you what antifreeze smells like when evaporating off a hot engine compartment (my car had a coolant leak a while back). It's got a far more unpleasant odor than gasoline, acrid and almost like burning rubber. It's not as bad as burnt clutch, though.
    Sorry if that sounds vague, it's tough to put into words. :)
