TR stalls with fans and AC on | FerrariChat
Discussion in 'Boxers/TR/M' started by Myhorse, Jun 27, 2016.
  1. Myhorse
    Myhorse Formula Junior
    Oct 31, 2003
    387
    My TR stalled a few times yesterday when coming up to a traffic light. was able to reporcude 100% of the time when the radiator fans were running and when the ac was on.
    I have the SR fusebox mod done. Connector are intact. New battery last year
    I suspect there is too much workload for the arthritic electrical system
    Anyone else have similar especially after the fusebox mod?
  2. Steve Magnusson
    26,806
    #2 Steve Magnusson, Jun 27, 2016
    I'd be more suspicious that your idle RPM is just set too low (or imbalanced). A reference from one the Pros who posts here that he targets the higher end of the warm idle RPM spec (with fans off and AC off):
    http://www.ferrarichat.com/forum/143749939-post5.html
    presumably to help when the fans and AC are on. I'd also add that my tach isn't too accurate (an actual 1000 RPM as measured by using a frequency counter on the RPM flywheel sensor signal reads ~1150 RPM at the tach needle).
