TR TROUBLE | FerrariChat
TR TROUBLE
Discussion in 'Boxers/TR/M' started by tr512, Jun 2, 2007.
  1. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Has anybody seen this before?
    I have lots,lots of pressure in my oil tank ,water is getting in, and a bit milky.
    the motor does heat up to 210 then the fans will come on.
    I know what you all are going to say....HEAD GASKET?
    But i don,t think so, I will tell why?
    The car idles fine,no white smoke. i,m thinking that the seal between
    the water pump and cover may be leaking and getting into my oil?
    oil pressure has got a bit higher.
    If my water pump has gone bad? can this happen?
    My car has never ran more than 195
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    If water is in the oil, then is the oil level getting higher, and is the water level getting lower? The pressure of the coolant system shouldn't be higher than about 16psi or so, the oil pressure is higher than that. Do you see oil in the coolant? I'm not exactly sure, but I think it is possible for coolant to get into the oil at the water pump. A head gasket problem would probably show up upon close examination of the spark plugs. Is there any coolant in the exhaust?
  3. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Water level is getting abit lower
    There is water in the oil ,lots of pressure when you open oil cap.
    NO oil in coolant
  4. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    no coolant in exhaust
  5. Steve Magnusson
    26,842
    #5 Steve Magnusson, Jun 2, 2007
    The oil tank getting significantly pressurized is not a good sign -- either:
    1. you have so much blow-by that the blow-by system is working, but getting overwhelmed, or
    2. The venting valve (item 8) in this jpeg has failed (or the little vacuum lines that tell item 8 to "open" have failed, come off, etc.).
    (I'll say this not knowing how difficult it may be to check, but) You need to confirm/deny if blow-by vapors are exiting valve item 8 and flowing in lines items 9 into the intake system. If you got no flow in lines 9 and valve item 8 is stuck closed, this would cause an overpressurization (I noted in the SPC that they redesigned item 8 once ;)). Alternatively, if a huge amount of blow-by is coming out lines 9, you'd have to suspect some serious internal mechanical engine trouble.
  6. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Thanks for the reply,but the photo you have up does not comply with my car.
    My car is a 1985tr and there is no blow by
  7. Steve Magnusson
    26,842
    #7 Steve Magnusson, Jun 2, 2007
    My mistake, but that's even stranger because on a TR the venting of the blow-by system has no valve (so the oil tank should never pressurize), but still same advice -- remove hose item 8 that enters the back of the airbox. Either hose 8 is blocked/kinked, or the amount of blow-by must be extreme.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The water pump should have a "weep hole" that will allow coolant to drain on the ground before pressurizing the oil seal. It is possible for this to get plugged. If you examine it underneath you should be able to check if it's clear with a thin wire. The cooling system pressure is around 15 psi. Oil pressure at the water pump might be less. It is possible for coolant to enter here but head gaskets or cracks are also good possibilities. It doesn't take much water to make the oil "milky". If you don't find an obvious source it will be time to systematically evaluate the possibilities.
    Putting air pressure into spark plug holes one at a time (piston at TDC) with radiator cap off, look for bubbles.
    Alternatively you can pressurize cooling system (no more than 15-16 psi) with spark plugs out and check for coolant in cylinders.
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    HI
    THanks for the reply,when the car is running ,which it runs fine.
    I opened up the oil cap and the oil shot out. thats why i,m thinking that my water pressure is leaking into my oil system pressure, somewhere to cause this. ABIT MILKY
    NOTE there is no oil in my coolant ,and there is NO white smoke coming out
    of my exhaust. HOT OR COLD.
    I did just change my alt , all hoses are hooked up? unless i missed something.
    I don't think so.
  10. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    Hmmmm....please forgive me for asking a seemingly stupid question. How are you checking the oil level? NEVER EVER check the oil level when the engine is cold. ALWAYS check the oil level after a short drive to get the engine up to normal operating temperature. After shutting down you have about 30 seconds or so to get back there, open up the bonnet, and check the oil level. If your car is cold right now, go out and check the oil level, if the oil level is between the min and max lines while the engine is cold, you have way way too much oil in you engine.
  11. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    You might want to drain the oil and inspect it, change the filter, and put new oil in to make sure you have proper amount in the engine. You will confirm if there is water in the oil by letting it seperate. Start simple. Work up from there.
  12. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,473
    Canada
    Newman
    How about taking it to a professional rather than wreck your engine. If you have coolant in the oil due to a headgasket (which is possible) then get it fixed rather than continue to feed milky oil to your crank bearings and cam journals. The consequential damage will be much worse by farting around and taking shots in the dark when you dont know how to diagnose it yourself.
  13. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    +1
    This doesn't seem to be one of those obvious do-it-yourself-ers, IMO.
  14. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I agree. Anti-freeze destroys bearing material. STOP running your engine!!
    From past experience.................
    Excess heat (or pressure) in the cooling system sounds like combustion gases being forced into a water jacket somewhere, possibly through a crack in the head (combustion chamber), headgasket or cylinder liner. The resulting excess pressure in the coolant could be forcing it past a gasket or seal that would otherwise prevent leakage between the two. This in turn could be causing excess crankcase pressure hence the oil spitting out of the oil cap (plus being over full).
    The engine can still run somewhat smoothly under these conditions but not for long.
    Coolant temps will be higher because of the hot combustion gases being injected into the coolant.
    I've seen this exact same thing before on more than one car.
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I wanted to add that sometimes, due to corrosion in the water jacket, pinholes will form in the heads allowing transfer. Deteriorating headgaskets will do the same thing for the same reasons.
    A common cause for excessive corrosion is the lack of coolant flushes throughout the life time of the car, lack of corrosion inhibiting additives and high mineral content of the water used to "top off".
    If the car has been over heated numerous times due to non-functioning radiator fans the head gaskets can be compromised.
  16. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    HI thanks for the reply
    I've owned 3 ferraris and know the cars well and do my own work.
    But this is my first TR.
    There is no PRESSURE in the coolant!!!! and the CAR does NOT lose COOLANT!!!!
    Thats what make's it strange?
    I did change the oil today and flush...same thing, oil got abit milky, but when the car sits for abit oil looks not that bad! until i start it.
    I think i will PULL the motor, there is a major problem!
    But i have done things with my ferraris that people said could NOT BE DONE?
    I,m going TO PULL THE MOTOR FROM THE TOP?
    YES I THINK IT CAN BE DONE!!!!
    I WILL POST PHOTO"S
    For you guy,s that don,t drive your cars much, thinking that something going to happen? Let me tell you a my little story.
    A ferrari that sits is not a happy FERRARI! MY first ferrari 15yrs ago was a 1980 308gtsi, i PUT #307,000 km that = about 200,000 mls for you USA guys
    The only major problem i had was that a valve broke at about 220,000km
    pulled the motor changed 1 piston,sleeve and had the head repaired.
    3 sets of tires,brake pads 3 times,changed belts and rollers 2 times, and valve addjustments 2 times, and rebuilt water pump 3 times. early 308 hard on water pumps. THATS IT
    NOT BAD FOR ALL THOSE MILES! and had fun driving it, NOT WATCHING IT SIT. thinking that something is going to happen if i drive it to MUCH!
    SOLD the car in 2001 still running great ,this car used NO OIL!
    I THINK IT LEAKED MORE, at the end 2nd and 5th syncro;s where on there way out.I don;t know where the car is NOW
    SECOND CAR 1983 308QV bought it with 38,000 mls US CAR .sold it to a friend
    of mine when it had 97000.00 mls with no problems whatsoever.
    Did change belts and valve adjustment ,rollers 1 time THATS IT.!!!
    HE drives it all the time,NO PROBLEMS to this DAY.
    MY TR i bought with 20000.00 mls US CAR ,the car sat most of it,s LIFE !!! VERY BAD FOR A FERRARI.
    Last owner did change belts and bearings at 18000.00mls in 1999.
    My TR now has 48000.00 mls and this is the first problem i,ve had with the car . THATS NOT BAD!!! i don't do stupid things with my cars .,burn outs,
    power shifts ,that kind of thing! BUT I DO REDLINE THEM ALL THE TIME...
    So thats my little STORY! AND ITS ALL TRUE.
    TO all the other FERRARI lovers like me,DRIVE your cars and enjoy THEM!
    IF something is going to happen? IT WILL.
    A HAPPY FERRARI IS A DRIVEN FERRARI!....YOU WILL BE HAPPIER TO .
    DRIVING IT.
    TO be honest i think on my TR, my head bolts came loose? and took out a head GASKET? WE SHALL SOON FIND OUT.
    Maybee when thay changed the belts they should of retorqued the heads?
    I was going to be doing my major this winter,but i guess i will be doing it sooner.
    I WILL KEEP YOU POSTED.
    IF anybody needs help with 308 or 328 i,m a real wis with these CARS.
    I,ve helped MANY PEOPLE fix there problems.
    THANKS AGAIN AND HAVE A GREATDAY.
    P/s just a little note about having to replace your belts at 30,000mls
    or 5yrs .thats a bunch of HOG WASH! thats only to make the dealers RICH!
    HOW COME a honda can go for 150,000 mls? .WHY....HONDAS are DRIVEN
    WE have tons of FERRARIS up here ,I have never heard of a belt braking?
    HAVE YOU?
    OR if it did? did you mis a shift ? and over rev IT? ....THEN MAYBEE?
    I REDLINE MY CARS ALL THE TIME.
  17. Bullfighter
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Whoa. Punctuation break...
    Well, obviously you're more mechanically gifted than I am if you can pull the engine. Good luck with it.
    And yes, I know of a couple of Ferraris that have had broken belts.
  18. Newman
    Dec 26, 2001
    14,473
    Canada
    Newman
    Thats nothing new, you can take it out the top or bottom. Post pics of the problem you find. Might be tough to find if its a liner o-ring.
  19. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I beg to differ.
    You ARE LOSING COOLANT! You are losing it into your lubrication system. It may not be hitting the ground but you are indeed suffering a loss, enough to turn your oil milky.
    There may not be pressure in your coolant but going from what you have written it sounds like the pressure is being transferred into your crankcase.
    The absence of white smoke only means none of it is making it's way into the combustion chambers. Usually a good sign.
  20. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    THANKS
    I don't seem to be losing coolant but it dosen't take much water to make oil milky.
    Do you know if TR's are bad for sleeve o/rings ? or how do you check them?
  21. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Every one i've ever talked to said that on a TESTAROSSA you have to split
    the frame? drop motor down
    Now i know on the tr512 the motor comes out from the top.
  22. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I have never heard of TR's having sleeve problems. The Ferrari flat twelve is one of the toughest ever built.
    The first thing I would do on your engine BEFORE taking it out is pressure test your cooling system. If it won't hold pressure you will have a starting point to trouble shoot from. Sometimes you can actually hear the leak during the test because the engine isn't running.
    Next, do a compression test and ESPECIALLY a leak down test. This will at least tell you if you are losing anything through your combustion chambers or headgaskets.
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    THANKS i will try this all tomorrow
  24. Newman
    Dec 26, 2001
    14,473
    Canada
    Newman
    It can come out the top too.
    Im not saying thats the problem, just never say never because thats how you miss things.
  25. Steve Magnusson
    26,842
    You guys are arguing two different points. With the clutch housing, axle shafts, and bonnet removed, the TR engine/gearbox can be lifted out the top -- obviously, you can't pull the whole powerplant & rear suspension out the top.
    tr512 -- If you are concerned about the oil tank getting pressurized, you should also be concerned that a lot of liquid engine oil is getting blown out hose #8 into the air cleaner -- I'd still say that your easiest 1st test is to just remove hose #8 from the back of the air cleaner and see what's happening there (i.e., massive blow-by coming out hose #8 = shut-off and big repair; absolutely nothing = maybe not so bad, but the air volume at the top of the oil tank and air inside hose #8 should be at equal pressures so that indicates blockage; a normalish amount of gentle blow-by = would be a surprising result given your report of a pressurized oil tank).
