$50K?...
IMO a lot of money when a similar amount will buy a Inter-Continential Brabham BT23B with a Climax engine . Unless there a significant car , period 60s open wheelers seam to be the same price value they were 20 years ago . Image Unavailable, Please Login Image Unavailable, Please Login
There you go Indy 500 2021 ...another 4 time winner of the greatest race . Image Unavailable, Please Login
I’m always amused when people say “Oh, you must be rich because you own a Ferrari”; My reply is always “I’d be a lot richer if I didn’t have a Ferrari to support!”
Racing next weekend (yay) so brake bleed and corner weights today Image Unavailable, Please Login Image Unavailable, Please Login
As a matter of interest, what torque is the wheel nut and tool used to do it please ? I was interested to here that 812s use 120 for their torque setting as opposed to 80 for the 355
400 foot pounds. I have a big air gun calibrated for it but at circuits use a 3:1 torque multiplier with a conventional torque wrench. Never had one come loose.
80nm? That can’t be correct. That’s sounds as low as 11psi. I could tighten to 80nm with fingers. I was always at 130nm.
Yes and no longer manufactured. For emergency I have spare steel ones that are much heavier, get the titanium ones crack tested regularly. I used to worry about work hardening of the nuts, but then I read "Skunk Works", written by the guy who ran the Lockheed special projects division. They built the SR-71 out of Titanium and were unsure about its life. After 35 years of flying, they were stronger than new.
Close enough Greg, my torque wrench is ft/lbs and I have it set to 85ft/lbs The guy with the 812 was told to do his to 120nm https://www.sparkyexpress.ca/blogs/auto-blog/ferrari-wheel-lug-nut-torque-chart I'm 1ft/lb below spec, oh no, my wheel will fall off Of course my wheel nuts are titanium so now I'll have to check that
