430 - Track Prep Checklist | FerrariChat
430 Track Prep Checklist
Discussion in '360/430' started by GogglesPisano, Oct 27, 2024.
  1. GogglesPisano
    GogglesPisano F1 Rookie
    3,351
    East Bay, California
    Joe
    Got talked to doing an HDPE event at Thunderhill this coming weekend. Nothing competitive. I’ve been to the track maybe 20-30 times with my S2000 but never figured I’d take the F430 out so this is a spur of the moment thing. Wanted to see if anybody had any track day check lists for before and after now that these cars are aging a bit. I don’t plan to flog it around the track but want to give the tires a run for their money. All fluids are fresh and topped off and just double checked my fuel pumps (both newer style with no leaking). Anything else I should be examining up close or checking for proper torque?
    ditpixs and colorfull like this.
  2. Racer_X
    Racer_X Karting
    Oct 20, 2017
    135
    MI
    Tom
    Always check that your lug nuts are properly torqued before racing.
    On a related note - check your tire pressure as well.
    LVP488 and GogglesPisano like this.
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,461
    Santa Clarita, CA
    Put Track Tape on the front surfaces of the car. A ton of rocks and rubber chunks get kicked up.
    GogglesPisano likes this.
  4. GogglesPisano
    3,351
    Joe
    Good idea. I already have PPF for the front but was thinking if I should do something on the rockers.
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,461
    Santa Clarita, CA
    Track Tape on top of the PPF on the forward facing surfaces and rockers would be best. The PPF is good for a street car, but it won’t be thick enough for track days. Track Tape is thick and peels off easily.
  6. GogglesPisano
    3,351
    Joe
    Thanks. Just picked some up off Amazon.
  7. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,225
    France
    It may be useful to also re-check the lug nuts torque during the day; adjusting the tire pressures is also a good idea: start with slightly lowered pressures, and then check and decrease again as the tires get hot.
  8. Lola360
    Lola360 Karting
    Oct 26, 2023
    158
    Bay Area, CA
    Connor
    Give the brakes a good inspection. Make sure pad and rotors are in good order. When was last brake fluid flush and what fluid are you running?
  9. GogglesPisano
    3,351
    Joe
    Stock fluid replaced by dealer last year. I have CCB's and they look to be in good shape.
  10. wiley355
    wiley355 Formula Junior
    544
    Vancouver, WA
    Wiley
    colorfull, Lola360, 3POINT8 and 5 others like this.
  11. RedTaxi
    RedTaxi F1 Rookie
    3,368
    New Zealand
    Glen
    Having tracked my 360, (now have 430) other than the obvious checks and having great tires, my first upgrade would be better brake fluid and pads.
  12. GogglesPisano
    3,351
    Joe
    Are you running ccb or steel? What fluid are you using?
  13. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,655
    San Jose
    dc
    I think there is better pure track rated fluid but Motul RBF 600 has decent wet values.
    Mario Andretti likes this.
  14. GogglesPisano
    3,351
    Joe
    When I was tracking the S2000, we all ran ate super blue. Haven’t seen much mention of that recently. Either way, not changing anything before the day but will likely do a quick fluid change afterwards.
  15. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,655
    San Jose
    dc
    Yeah super blue is a bit dated compared to the Motul but I also ran it. Stained your reservoir though.
    I believe the idea was you would cycle between the ATE blue and yellow so you could tell when you had 100% swapped over.
  16. 3POINT8
    3POINT8 F1 Veteran
    5,506
    good for you for tracking it. please give us a full repor!
  17. swc5150
    swc5150 Formula Junior
    Jan 5, 2021
    755
    Wisconsin
    Scott Calderwood
    Track insurance and have fun! Our dealer sponsored a track event for club members and even supplied instructors. I got to experience our car with a pro driver and wow! After a few mind blowing laps, he pitted and told me "that was about 70% of what your car is capable of".
  18. Lola360
    Lola360 Karting
    Oct 26, 2023
    158
    Bay Area, CA
    Connor
    Unfortunately super blue was outlawed by DOT simply because of it's color, years ago. You won't be finding it anymore. Too bad because it made flushing fluid so easy.
    I would be really careful with stock fluid, even with CCB. Or at least check the wet & dry boiling points of it and compare to something like Motul 600 / 660.
  19. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,185
    Wash DC area
    Robert
    Remove all floor mats and other loose items.
    Tape over headlights, don't want broken glass on track.
    Bring plenty of water and stay hydrated.
  20. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,225
    France
    Latest from Motul is RBF 700 :) - allegedly the best DOT4 fluid I guess.
  21. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,154
    link to track tape purchase?
  22. GogglesPisano
    3,351
    Joe
    Edward 96GTS likes this.
  23. Lola360
    Lola360 Karting
    Oct 26, 2023
    158
    Bay Area, CA
    Connor
    Ah yes 700 now. Although I think title for best DOT4 fluid goes to Castrol SRF, which it ought to be the best at $55/L. It's main advantage is the wet boiling point at 518F. Compare to other fluids, RBF700 for example, wet point is 401F. It's really the wet point that matters, unless you are changing your brake fluid every event.
    https://www.lelandwest.com/brake-fluid-comparison-chart.cfm
  24. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,225
    France
    Indeed wet point is more important as it protects on the "long" run.
    I read that some brake ducts will not be happy with some silicon contained in the Castrol SRF, while the Motuel does not contain silicon - I wonder what the situation of the Ferrari equipment is.
  25. fatbillybob
    Aug 10, 2002
    29,464
    socal
    Here is a very minimum list from 2 popular trackday organizations. Do this yourself or hire a pro. I would also add for streetcars remove all floormats so feet don't get stuck and pedals fouled. Bring tire gauge with you and torque wrench for wheels. A battery power air pump is nice but most likely as the day gets hotter air will be bleed off from tires to get to your hot pressures on track. Remember to air tires back on way home because you will not make as much heat on the way home. Check wheel torque before every session going out on track. I would also recommend good stock brake fluid nothing fancy until you know the car and have some trackdays with it to find the weak spots. Fluid should be the weakest link in your brake system. Boiled fluid tends to give lots of warning brake are going seen as a spongy pedal. What you don't want is the unlikely event where your fluid is so good the next failure point is the brake caliper seals. You can design a brake system where all components are on the limit and get a job with F1 team. I'm willing to carry the extra weight and rotating mass so that I can use cheap autoparts store $8/L valvoline dot 4 brake fluid. In fact for my spec corvette racecar the aftermarket brake system is so good I travel raced 7 races this year and never had to bleed brakes or change brake pads until my car got shipped back home. Contrast that with the stock OEM brakes where we spread calipers in 1 year, wore new race pads in 1 weekend and cracked the rotors on the 3rd trackday!
    E60 M5 and GogglesPisano like this.
