Transaxle fluid top-up | FerrariChat
Discussion in '308/328' started by skipgt4, Jun 15, 2024.
  1. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    I removed the transaxle inspection plug and the fluid is just a little low, so I was going to top it up.
    Can I do this from the inspection hole or should I do it through the transfer case fill hole?
  2. bill brooks
    bill brooks F1 Veteran Silver Subscribed
    Jul 30, 2007
    6,049
    waynesburg,pa
    bill brooks
    if you replace thru the x-fer case fill hole, leave the inspection hole unplugged on the diff. until fluid drips out.
    leave things sit for a few minutes and then re-check for too much or too little.
    i'd changed my 328 many times in this manner. i believe this is Ferrari's accepted procedure.
    Cameron Henlin and moysiuan like this.
  3. JohnnyS
    JohnnyS F1 World Champ Owner Silver Subscribed
    Oct 19, 2006
    15,280
    Illinois
    You can add a bit through the inspection hole. It probably won't take but 2 or 3 squirts from a quart style oil pump.
  4. absostone
    absostone F1 World Champ Silver Subscribed
    Jul 28, 2008
    10,025
    Be sure the car is leveled
    moysiuan, Rifledriver and Vinsanity like this.
  5. Rifledriver
    37,090
    Never seen the top plug used for filling in a professional environment in over 40 years.
    With car level put a pint in the top plug and fill in the rear plug until it overflows.......done.
    Lets not overthink this.
    tomberlin and Cameron Henlin like this.
