Transfercase/Dropbox tool and torque spec | FerrariChat
Discussion in 'Boxers/TR/M' started by kerrywittig, Nov 17, 2014.
  1. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    I am doing my 4th waterpump seal replacement (more on that later) on my '87 TR and a second belt service as long as I'm in there AGAIN!...
    But I noticed a slight weeping of gear oil between the bellhousing and the housing where the 3 gears that transfer power from clutch pack to the the quill shaft. So I have split the case to reseal/gasket the cases. In order to seperate the cases I had to remove a ring nut. The ring nut gets pretty much destroyed when you remove it because it has 2 peened areas that "lock" it onto the shaft/gear. So I orderd a new one, Ferrari PN. 153068 ($40) and then proceeded to try to locate the appropriate ring nut socket (RNS) to insure that it is tighted back on the shaft/gear body correctly....I have great news and a question....
    First, the question....What is the correct torque that this ring nut requires?
    Secondly, the good news....You can buy the ring nut socket (RNS) from Hill Eng. PN. RNT-50/Ring nut tool - 50mm for $100+ or....you can go to ANY NAPA store and buy PN. 2467 for $24.......it fits perfectly! It is a 4 wheel drive spindle nut wrench that is actually for Ford 4x4 truck front axles.....It does not have a horsey embossed on it and it is made in USA, but it will do the job just as well....even though it may not instigate Florida barfly girls to pose with your Italian dicks on wheels.
    But I really do need that torque spec please...Thanks!
    I'm Back Me
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    Photo(s) please Kerry ! :)
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,531
    romano schwabel
    this nut is the same as on the drive shaft
    the torque you need is 220 Nm ( on a TR , but I think it is the same on your car )
  4. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    #4 kerrywittig, Nov 17, 2014
  5. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    So....220Nm equals 162 lb/ft??
  6. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    According to the online conversion tool that I use, you are correct.
  7. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Nice....;)
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    This is how I remember it....
    Think of Newton - the guy that dropped an apple.
    An apple is about 1/4 lb
    .....220 Newtons (apples) is 220/4= 55lbs
    A meter is about 3 ft and torque is the lever arm x force
    .....3 ft x 55lbs = 165 ft lbs
    It is obviously not exact - but you can do it in your head as a 'reality check' to confirm your conversion by more exact means.
    Rgds,
    Vincenzo
  9. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Thank you TJ and V...
  10. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,575
    Avvocato
    This may sound silly, but do those teeth look like they can handle that type of torque
  11. turbo-joe
    Apr 6, 2008
    9,531
    romano schwabel
    I already thaught the same. for one or two attempts to tighten it may be good. but to open with an air impact wrench I see problems
  12. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Here we go!!
    Make a suggestion that does not have a "Ferrari" endorsement, or a prancing horse scribed into or onto it and god forbid that it costs a resonable price...........and it's sub-par....amazing.
    Shaking my head...again....Me
  13. MS250
    Dec 10, 2003
    26,575
    Avvocato
    Was just a question Kerry, take it easy partner.
  14. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #14 vincenzo, Nov 19, 2014
    Good question! Thinking about my Ford... The rear axle outboard bearing retainer on the F250 uses a similar tool. It is used to torque to the factory spec of 55 to 65 ftlbs.
    Enclosed is the TR WSM info.
    As I read it (YMMV):
    PN 31 is a "Ring Nut" (is that the one you seek? or is it the layshaft RN?) per the TR WSM torque tables, the "Ring Nut to Clutch Shaft" calls for 20 daN m.
    One decaNewton is 10 Newtons. The 20 daN m is 200Nm...
    Going thru the "in the head" conversion: 200/4*3=150ft lbs
    Doing it exactly, per Maryland Metrics: Online Metric torque conversion Calculator we get 147.6 ftlbs.
    Yup -
    The 147.6 ftlbs does seem to be a very high load on that tool - but it seems to be the WSM's specified torque.
    (pls confirm which 'ring nut' you seek in the below shown tables)
    Rgds,
    Vincenzo
    PS: If the torque value is right - the 'tool' should be good to go.
  15. turbo-joe
    Apr 6, 2008
    9,531
    romano schwabel
    I think you have been talking first about the ring nut no. 6? this has 220 Nm
  16. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Kerry - similar set up as on the 308. 308 repair manual gives torque as 20 kgm which converts to 144.66 lb-ft.
  17. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    #17 kerrywittig, Nov 24, 2014
    Wrap up...
    $24 NAPA socket worked perfectly, as I suggested it would.
    Thanks to all for the torque specs...I pulled it to 150 lb/ft.
    Dropbox all back in one piece.
    New waterpump seal installed....again! Mr. David Helms came to my aid on this one...correct seal, custom made spacer, machined the impeller, along with machining & updating my installation tool (also NOT Ferrari issued).
    New belts & clutches dismantled and checked, re-cored radiators in place with all new hardware also while in there....10 hours and service is done!
    Gold kit is ready for installation and then another 4 hours to get it back in place and on the highway.
    Almost done Me
  18. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Don't rush the gold kit install.. Take your time and be precise.. It will payoff big time.
    R
  19. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Glad to see some new help is coming into the marketplace for the WP seals. Any pics or PNs or additional info would be much appreciated. Is Dave going to be doing this on a routine basis, or was this a one-off project?
    Congrats!
    Vincenzo
  20. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    David is doing this for all weeping and dripping Testarossa owners...I believe I was one of the first to take advantage of his help....just as he has helped with hoses, electrical connections and electrical power distribution upgrades he is now providing this service ....I'm sure David will soon speak up concerning this very much needed service. I can tell you. I was VERY frustrated with these waterpump issues....even Ricambi has STOPPED offering waterpump seals.......PITA for them...Dave it seems has found out what it takes to get results that work...time will tell.
    My install tool is one I pirated (with permission) from a fellow FChat member whom was kind enough to lend me his for many months....If anyone out there is interested I can post some pix. I redesigned it a bit and made certain parts of it out of different materials to perform better with the seals and to provide very easy to find replacement "wear" parts.
    Formerly weeping Me
  21. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Kerry, please post some pics of the tool and the mods you did to it. Sounds like your car is getting close, congrats.
  22. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
