Transmission damper | FerrariChat
Transmission damper
Discussion in '365 GT4 2+2/400/412' started by GT Jones, Jun 14, 2013.
  1. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    #1 GT Jones, Jun 14, 2013
    This bushing at the rear of the transmission has been soaking in trans oil for so long that it's now softer than a gummy bear. I'd replace it but I can't seem to find a part #. Any ideas?
  2. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    Bushing is #105634.
    Pain to remove and install as it needs to be pressed out and pushed in.
    M
  3. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    It's June and my winter project list is already a mile long... Thanks for the part#
  4. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Cut it out with hack saw or similar and then you can clean it up and press in the new one. It was on my winter list about 3 years ago.
    Does your tranny leak? I have fought leaky pans for 2+ years and finally think I have it licked. If that is a general issue, let's start a new thread.
    Ken
  5. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    I cleaned the underside last weekend and will try to track leaks over the next few hundred miles. Sure looks good, for now...
  6. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    #6 GT Jones, Feb 9, 2014
    I did this job today and a few notes. Chiseling or hacksawing the bushing out wasnt something I was going to try. I made up a tool using a combination of long bolts, large 32mm & 46mm sockets and some thick washers that allowed me to push the old bushing out and draw the new one in. I tossed the bushing into the freezer before installing although I'm not sure if it makes a difference.
    The bushing is 42mm OD so you need to find sockets with a slightly smaller (41) OD and one that has an ID that will grip only the metal shell of the bushing.
    The transmission case is chamfered on one side so be sure to start the new bushing on that side. The new bushing had almost no chamfer to the ends so I filed one side a bit to ease installation. It pressed right back in without much drama.
  7. Ak Jim
    Ak Jim F1 Veteran
    9,617
    North Pole AK
    Have a picture of your improvised tool?
  8. 400iGuy
    400iGuy Formula 3
    1,078
    Central Florida
    Al
    Thanks for sharing. This is on my list although winter doesn't much matter around here. July/August would probably be a better time considering when the car gets used!
    I agree, a photo of your improvised tool would be great too.
  9. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    GT
    I'm pretty careful about cutting bushings out; you only have to go far enough for metal to get weak and it will push out. Looking at your housing it looks like someone was not so kind in the past. I did install same as you but without the chamfer; I did not notice chamfer on one side of housing, maybe I guessed right. Pick the right socket and bolts and in it goes!
    Ken
    p.s. My car was back on road for some miles and now at Exoticars USA for new timing chain and tensioner.
  10. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    #10 GT Jones, Feb 10, 2014
    I'm not in the shop tonight and the tool (2 large sockets, a long bolt and some washers) is back in two different drawers. Here are pics of what I copied: this tool fits the 308/328 bushing which is just a few mm different.
  11. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    #11 GT Jones, Feb 10, 2014
  12. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Ken, I'd love to meet some of the former mechanics who worked on my car...
    What's the quote to replace the chain and tensioner?
  13. Ak Jim
    Ak Jim F1 Veteran
    9,617
    North Pole AK
    What exactly does this bushing do?
  14. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    The 4 engine and trans mounts support the driveline. There's a steel rod that is rubber mounted to the frame and through this bushing to keep the driveline from moving longitudinally. While mine was soft and oil logged once I cut it apart I realized that there's very little rubber in the bushing and the center portion was pretty solid. I doubt that one could ever feel the difference with a new bushing.
