Transmission doughnut GTC4 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by naiyvel, Feb 20, 2008.
  1. naiyvel
    naiyvel Rookie
    Oct 11, 2005
    7
    I need some information on the rear transmission doughnut on the GTC4.
    Does anyone know what other cars share this item?
    Ian L
  2. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    I presume you mean the CV joints.
    These are available from GKN Driveline. I think you will need to give them the dimensions as I think they can't openly supply 'Ferrari' parts. I believe they're also used on some UK Fords amongst other things.
  3. naiyvel
    naiyvel Rookie
    Oct 11, 2005
    7
    Hello
    The part I was asking about connects the propellor shaft centally to the differential. It is rubber moulded around a steel framework & has 8 bolts;4 conenct to the end of the shaft & four bolts connect to the diff.
    A similar arrangement was used on the original Lotus Elan
    Ian L
  4. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    I'm puzzled.
    I thought the 365 GTC/4 should have a solid splined coupling between the drive shaft and the diff, all inside the torque tube.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #5 2NA, Feb 22, 2008
    There's a splined coupling that conects the hard metal pieces together at each end but the "torque donut" absorbs the shocks and is mounted to the front of the diff. Similar in design to (but much larger than) the flexible coupling (Metalastik) found on steering columns.
    I think only the GTC/4 used the part, probably getting kinda scarce.
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Yes and was a crappy design on the Lotus. Does it work any better on the Ferrari?
    Ken
  7. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    isnt that used on a lot of the vintage ferraris with the transmission in the front(ie: trans attached to the motor)
    i think Tom Yang talked of his 330 America using that type of connection right at the trans tunnel....
    also a lot of alfa use a "guibo" like that at both ends of the driveshaft?
    i dunno. im just waiting for the weekend :)
    doug
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Some of the 330's used a similar part, different #
  9. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    2na - Thanks for posting the parts book picture.
    I wonder why they used the donut on the GTC4 and not the 365GT 2+2, 365GT4 2+2, 400/412 which have the same torque tube arrangement (though longer). Also no donut on the torque tube/transaxle cars from Daytona through to 575.
    Naiyvel - I guess you've tried Eurospares, although they will be much more expensive than sourcing it yourself, should be cheaper than Ferrari
    Unfortunately the donuts used on single seater driveshafts are usually 6-bolt
  10. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    www.reoriginals.com list an 8 hole donut - E0053X - about $360
    I don't know if it's the right size
  11. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,293
    Ian: I always thought the C4 and the Queens had the same configuration, there is someone you could check with, PM sent, M
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I suppose one reason the transaxle cars didn't use the "Krispy Kreme" was because the driveshaft is always spinning at engine speed. It might be tricky to get that big rubber thing to stay in balance.
    Here's a tip: When you replace the donut the new one comes wrapped in a metal band, DO NOT REMOVE THE BAND until after it's bolted together.
  13. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    Queens definitely don't have the donuts. I just checked my parts book.
