Transmission Fluid change 355 | FerrariChat
Discussion in '348/355' started by SA Mike, Sep 7, 2019.
  1. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    How often, what brand, how many quarts, etc..
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,583
    San Carlos, CA
    Mitchell Le
    annually changed..
    MTL from Red Line.
    4 quarts.
    SA Mike likes this.
  3. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thank you sir! Weight?
  4. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Check it after 4 quarts, I think mine took 5.
  5. QSA
    QSA Formula Junior
    Jun 3, 2011
    302
    Kingwood, TX
    Quinn
    Only one weight of MTL. 75w80.
  6. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,238
    CT
    John Kreskovsky
    ShineKen, WATSON and SA Mike like this.
  8. Qavion
    Qavion F1 World Champ
    14,333
    Ian Riddell
    #8 Qavion, Sep 8, 2019
  9. johnk...
    Jun 11, 2004
    11,238
    CT
    John Kreskovsky
    That's a joke. Maranello Classic Parts lists an alternative part Re Change Notice 102. Standard copper washer. Pretty common sense change. Why anyone would use anything else is a mystery to me. https://www.ferrariparts.co.uk/part/ferrari/144485?id=42370
    I never knew there was an actual change notice, but have always used copper washers.
    WATSON and Skippr1999 like this.
  10. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thanks for the replys. This forum is awesome! The manual says 75w90 GL-5. This is correct weight right?
  11. WATSON
    23,708
    WI
    +1 I still use copper washers. I buy them from Aircraft Spruce.
    If it leaks I'll change. Until then, no.
    Qavion and JLF like this.
  12. 308 GTB
    308 GTB F1 World Champ
    11,729
    New Jersey
    Barry Wolinsky
    Changed annually
    Royal Purple Max Gear 75W-90 Full Synthetic Gear Oil
    5 liters
  13. tatry68
    tatry68 Karting
    Oct 27, 2013
    120
    Chicago Suburbs
    Stan
    I use royal purple in mine too. However, I just came back from Europe and I found some Eni Rotra LSX 75W-90 which is on the way. I will see if there is any difference in cold shift quality with the oem oil in the gearbox.
  14. ClydeM
    ClydeM F1 World Champ
    11,935
    Wayne, NJ
    Clyde E. McMurdy
    When I 1st got the car, I asked the mechanic to change the trans fluid not knowing it's condition. I saw him fight trying to get the hex screw out.
    I suspect there wasn't a washer/gasket at that time which is what made it so difficult and he didn't put one on. oops.
    Car went through a major & no mention was made.
    I just changed the fluid today and tried to remove the plug before draining the oil - :)
    It was a battle. But today I noticed it still had no gasket/washer. I'm blaming missing gasket for hard-to-remove & will put one on this time. Copper. Somebody have the ID & OD? Same as the oil?
  15. Rifledriver
    37,110
    #15 Rifledriver, Feb 22, 2020
    Ferrari is using a lot of aluminum banjo fittings and banjo bolts and their torque spec makes copper rings a little unreliable. They went to Dowty rings on them and have superseded earlier copper rings of the same size to Dowty rings.
    Buying any of that class of part from Ferrari is just crazy. Despite the requirement to do so I have never worked in a dealer who bought that kind of stuff from Ferrari either. The copper 22 x 29 is about 50 cents.
    Qavion likes this.
  16. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I finally just just got a 5 gal pale of Shell Spirax S5, I'm using Amsoil now and it does not work that well. Its a 348 but same difference.
  17. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    I recently switched from Redline to Shell Spirax S5, noticeably better shifts.
    ShineKen likes this.
  18. ClydeM
    11,935
    Wayne, NJ
    Clyde E. McMurdy
    Thank you.
  19. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Where did you buy it?
  20. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    You can find it online, California, New York etc, find one close to you to reduce shipping cost. I "think" Spirax S5 is the ONLY Ferrari approved gearbox oil, Porsche too but they re-brand it as far as I can tell. The Amsoil may work well in a Munci 4 sped but in a transaxle its not working so well, I have a case of redline sitting on the shelf but I decided to go with the mfg recommendation.
    See recent 355 post -> https://ferrarichat.com/forum/posts/146935189/
  21. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
  22. johnk...
    Jun 11, 2004
    11,238
    CT
    John Kreskovsky
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ohh there is definitely something to that no doubt about that ha ha! :)
    That said, there are many posts in threads easily missed that attest to how much better the gear box is with it. Who knows....
    MAD828 likes this.
  24. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    987
    +1 The Dowty washers, or bonded seal rings are the way to go. here is a great deal on an assortment kit:
    https://www.ebay.com/itm/Swordfish-31981-150pc-Automotive-Dowty-Bonded-Seal-Washer-Assortment/181942327614?epid=14018755340&hash=item2a5c9b993e:g:3tQAAOSwPc9W0SZe
  25. Rifledriver
    37,110
    Not in my opinion or that of my clients.
