Transmission mounts for 1994 348 | FerrariChat
Discussion in '348/355' started by ForsytheFotographyHouston, Aug 8, 2013.
  1. ForsytheFotographyHouston
    129
    Houston Texas
    Eric Forsythe
    Ok, I give up! I cannot find any new transmission mounts for my car. Anyone have any real suggestions? Help!
  2. ForsytheFotographyHouston
    129
    Houston Texas
    Eric Forsythe
    Well, I found them at Ferrparts.com. Thanks for all the help and multiple responses! :/
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Lol!
    Don't feal bad. Nobody responded probably because they don't know. But thanks for letting the rest of us know where to go.
    Say are you gonna post a DIY tread, with pics, when you changing the tranny mount?
  4. ForsytheFotographyHouston
    129
    Houston Texas
    Eric Forsythe
    Well, guess what? Ferrparts charged me for the mounts, but they never had them. I have been waiting for them. No one called to inform me. My car is in the air at FOH. Now I am on the hunt for them again! Part #139230 I need two. Feeling pretty screwed right now.
  5. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    #5 lbell101, Aug 16, 2013
    Ricambi has that part number for sale on their website.
    EDIT: Listed at zero dollars so probably not!
    Larry
  6. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Try calling GT Car Parts in Arizona. (623) 780-2200
  7. ForsytheFotographyHouston
    129
    Houston Texas
    Eric Forsythe
    I called them. They were very helpful but they came up with nothing. So I am still on the hunt..
  8. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Did you try either T Rutlands or Lyle Tanner? Sometimes you get lucky. Also you might find some recycled ones that will do.
  9. ForsytheFotographyHouston
    129
    Houston Texas
    Eric Forsythe
    I will try Lyle Tanner. Rutlands is a no go...
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #10 Wade, Jul 25, 2015
  11. Ricambi America
    Sponsor Owner
    Hey, I know that photograph. ;)
  12. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    But do you know where one can buy the parts? ;)
    Seriously, even though I don't need them right now, I'm curious.
    To the OP, those look a lot like some BMW rear subframe bushings. Probably more trouble than you want to go to, but if you can't find them elsewhere you might be able to machine polyurethane BMW bushes to fit.
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Just trying to support our sponsors. :)
    A proactive approach is my plan. While I don't need these mounts right now it would be good to know of their availability. Fortunately the 348 doesn't eat these things like some of my previous cars.
  14. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    It would be great if someone could provide dimensions so we could do some comparisons as time & opportunity permit.
  15. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    #15 m.stojanovic, Jul 26, 2015
  16. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
    If these are a match, we can add this to the 348 parts list.
  17. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    *bump.... so, are they a match?
  18. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Great question!
    Surely someone has a used 348 upper mount bushing that they can measure for us all. :)
  19. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    At 12.95 (google search) each x'2, worth the gamble! I've spent more on a few bad drinks in an evening.
  20. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    #20 driveitdaily, Feb 22, 2016
    IIRC, wasn't there an older fiat model that used the same basic transmission as a 348. ? That may be a possible source thru fiat.Maybe it was an alfa , damn I know for sure that I read this somewhere, just cant find or remember where.
  21. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    There are quite a few BMW models that use similar rear subframe bushes but they are of different dimensions, so there are several potential replacements right there. Even if none are an exact fit it would likely be possible to fabricate pieces to replace the Ferrari mount that use a BMW bush instead of the original.
    There are a number of companies that make polyurethane replacement bushes or BMWs and other cars so that's yet another avenue to investigate. Also, I've heard of people injecting liquid urethane into the voids on stock bushes in order to reduce the flex built into factory rubber bushes. It apparently works better than you might think, although I don't know how long it lasts. Might be something to look into as a means of repairing a failing mount if you catch it before it fails completely.
  22. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #22 Wade, Feb 22, 2016
  23. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    I tried to measure the diameter of the original mounts (in situ, not very accurate) and I think they are a few mm smaller than the BMW mount. Looks like it is possible to make them fit by machining the outer sleeve down but it seems that it would make it very thin. BMW mounts are also obviously shorter than the originals (which may not really matter). In any case, the best is if someone can provide the measurements of the original mount.
  24. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    If they're few mm smaller then maybe e30 rear subframe bushes might work. No idea if they're smaller than the e32 bushes but they may well be since its a smaller/lighter chassis.
