Transmission Oil Level | FerrariChat
Discussion in '360/430' started by trainsplanesandautos, May 16, 2014.
  1. trainsplanesandautos
    Feb 21, 2010
    131
    Burleson Tx.
    Mark
    When checking the gearbox oil level do you screw the dipstick in or just set it on the top of the hole?
  2. Tim1137
    Tim1137 Formula Junior
    Aug 16, 2011
    817
    Providence - Boston
    Tim
    Screw the dipstick down I believe. I just did my fluid this past week.
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    Per the manual: 7.35
    CHECKING THE TRANSMISSION DIFFERENTIAL OIL LEVEL
    - Idle the engine for about two minutes and wait for five minutes after stopping the engine.
    - Unscrew the oil filler cap (a) found on the left hand side of the transmission. Check the oil level with the cap resting on the seat. It should be between the "MIN" and "MAX" notches on the oil dipstick.
  4. Tim1137
    Aug 16, 2011
    817
    Providence - Boston
    Tim
    I interpreted "resting on the seat" as screwed down. The "seat" being the actual area that the top of the plug "sits" on once screwed down.
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    But they also say to "unscrew" the cap in the first sentence of the same bullet point. If they wanted you to screw it down to check the fluid they would use those words rather than have it say merely, "resting on the seat," wouldn't they? At least that's how I read it. The instructions are not the model of clarity and I suppose can be read both ways.
  6. Starfish
    Starfish Rookie
    Feb 28, 2012
    40
    So Cal
    IMHO..."resting" on top, is not screwed in.
    I'll play the straight guy on that one and let others chime in.
  7. vrsurgeon
    16,543
    Charleston, SC
    Curt
    I interpreted it as resting, not screwed in, on the seat. I'm not going to run my tranny with too little lubricating fluid. If you screwed it in and had the fluid at the max mark it would probably be OK though..
  8. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Same procedure as checking the engine oil -- resting on the seat not screwed down.
    Alan
  9. London
    London Karting
    Aug 29, 2009
    189
    London
    I've recently been told by a Ferrari mechanic whom I trust that, regardless of what the WSM says, the correct oil level is obtained with the dipstick screwed in.
  10. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Maybe we need to see the instructions in Italian, to be sure of an accurate translation!
  11. London
    London Karting
    Aug 29, 2009
    189
    London
    #11 London, May 16, 2014
    I'm Italian, and the WSM translation is accurate (copied below) ie it says it should not be screwed down - but it wouldn't be the first time the WSM is wrong...
