Transmission pan detent spring recess measurement | FerrariChat
Discussion in '308/328' started by SeattleM5, Jan 4, 2025.
  1. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Happy New Year everyone! By chance is anyone doing a winter project that required them to remove the transmission pan? I'm trying to figure out how deep the recess is in the pan for the 1st/Reverse detent spring/ball. Thanks in advance for any information folks can provide.
  2. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    I have a spare pan in the shop somewhere, I’ll be there a bit later if nobody chimes in
    SeattleM5 likes this.
  3. Steve Magnusson
    26,794
    I had a little "simulator" piece made to hold the springs with the gearbox pan off (for my 1978 ex-308), and measured it at .49" (although it's probably 12.5 mm deep):
    Are you doing something similar, or making a whole new pan, or doing something even crazier? ;)
    SeattleM5 and ChevyDave like this.
  4. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thank you! Thank you!! Thank you!!!
    Exactly what I'm doing Steve, making a 'simulator' to hold the detent springs in place while the pan is off so I can do the shift shaft alignment. I know Verell sells one but haven't heard from him after sending an inquiry so I'm going to make it myself in the shop. Did the same recently when I needed a Delrin shift shaft bushing made. Posted about that several weeks back.
  5. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    If you wanna be very lazy, I saved the pan to chop it up to Make the tool, you can cut it and use it and just give it back to me whenever you’re finished
    waymar likes this.
  6. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thanks Scott! I was going to go that route and buy a used pan to chop up until I saw how much they are going for! I think I'll go ahead and make the part, it will be a fun project to do with my son and my father in the shop. My Dad will turn 90 later this year and the more time we can spend together the better.
    smg2, flyngti and moysiuan like this.
  7. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    I need to take some measurements of that American flag thing you’ve got, rear bumper, and front
  8. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Anytime!
  9. Cameron Henlin
    Cameron Henlin Karting
    151
    Roseburg OR
    Cameron Henlin
  10. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thanks for sharing this, love the community here! I ended up machining something out of aluminum with the milling machine using Steve's measurements in post #3. Haven't used it yet as it will be a bit before I get the car on the lift.
  11. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    I found my detente balls were 8mm and no chrome showing plus prior owner had sooo much silicon sealant in these area.
    5/16" chrome ones at Home Depot are 7.9mm and work better now
    Are you adjusting the shifting system?
  12. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    My 1-R detent ball moved freely in its bore but would not drop out of the end of the bore bushing so I left it in there while doing a recent gasket replacement. The 2-3 ball was slightly larger than the 4-5 ball, and it looked to me like someone had reamed out the 2-3 bore bushing at some point, which might explain why they put a slightly larger ball in there. I had ordered spare balls and springs in case they were needed, but ended up sticking the previous parts back in.
    Here's a pic showing my 328's 22 year old gasket in the area around the detents:
    Has anyone seen this deformation/tearing on the gasket before? It looks like over time, gear oil trapped inside the bores of the R-1 and 2-3 detents squirts out the bottom when the balls move down, and it bulges/tears the gasket in that area. The 4-5 detent has an additional spacer that seals off the bottom of its bore, and the gasket looks fine in that area.
    I did notice a change in shift feel with a new gasket and different gear oil (Redline MTL), where there is now a light "drag" feel in the shifter in the 1-R and 2-3 gates, I assume because the new gasket is sealing off the bottom of the detent holes and gear oil is trapped in the bores and creating some resistance when the balls need to move. It may be the normal feel and I had just gotten used to the way it was before with the torn gasket.
