Transmission problem on 308? | FerrariChat
Discussion in 'Technical Q&A' started by losang, Jul 11, 2009.
  1. losang
    losang Karting
    Feb 11, 2005
    153
    I am afraid to ask because I think it could be ugly but yesterday I was heading down the highway at 80 MPH and I literally lost all of the gears. I almost came to a stop when I finally found second and got it going again. From that point on it was fine as I headed straight home. What do you think it is?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You will need to be more specific than "lost all of the gears".
  3. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,322
    Germany
    Steven
    i suggest you go back to the place you last used them, they might be laying around somewere....
    but to follow the previous answer, what EXACTALLY went wrong
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    Could be just linkage adjustments.
  5. garybobileff
    garybobileff Formula 3
    Sponsor
    Feb 5, 2004
    1,181
    San Diego CA
    Gary
    I would check the silentbloc ( bushing) in the shift shaft just in front of the gearbox ( exterior). If this bushing is ok, and not fallen apart, I would then drop the trans pan, and check for a loose piece of hardware in the selector mechanism. To lose all the gears is a linkage /actuator problem, and not a gearbox problem requiring overhaul. Rest easy, seems like a minor problem, easy fix.
    Gary Bobileff
  6. rdearing
    rdearing Rookie
    Feb 7, 2006
    11
    What you will most likely find is one of the numerous adjustment points in the shift linkage (internal and external) has moved,allowing the primary shift fork to jump out of alignment. should be a quick fix.
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Nice post!
  8. mwr4440
    58,189
    Bavaria, The 'Other' Germany
    Mark W.R.
    This, one or both of the silent block bushings are bad or the fork came loose on the shift shaft inside the transmission case.
    Those are my bets.
    He COULD get lucky and this be an easy fix, but I WOULD BE PREPARD to drop the transmission pan to get the adjustments correct again and all grears working properly. AND I believe this will most likely be the case.
    Oh, and while you are in there, change seals, but in new silent blocks ............. etc.
    Don't bother asking how I know ................
  9. ClydeM
    ClydeM F1 World Champ
    12,221
    Wayne, NJ
    Clyde E. McMurdy
    I had something similiar happen. As above, the linkage bushing went. after replacing it, 2K miles, the other disintegrated. Do both if one.
