Transmission Whine | FerrariChat
Transmission Whine
Discussion in '206/246' started by DinoDanGT, Sep 1, 2010.
  1. DinoDanGT
    DinoDanGT Rookie
    Aug 11, 2010
    3
    Minnesota
    Dan Bruggeman
    My '72 Dino has a lot of whinning in 1st-3rd. Not so much in 4th and 5th.
    I know they are loud but at 30 MPH the tarnny is louder than the engine.
    I'm guessing it's a bearing?
    Could it be the diff?
    I am running RedLine 75W90 gear oil.
    Any suggestions.
    Thanks in advance-Dan
  2. UroTrash
    Jan 20, 2004
    40,486
    Purgatory
    Clifford Gunboat
    #2 UroTrash, Sep 1, 2010
    Welcome to the board!
    Has the sound changed?
    when was the last fluid change?
  3. UroTrash
    Jan 20, 2004
    40,486
    Purgatory
    Clifford Gunboat
    #3 UroTrash, Sep 1, 2010
  4. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    The Dino trasmission needs specific oil for mid mounted engines.
    Due to the fact that the trasmission housing includes the engine oil pan
    it heat a lot more heat than a normal trasmission.
    The right one is for example: Castrol SAF XJ 75W-140
    Regards
    Nicolai
  5. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    A perfect time for me to exit since the Dino is sold and a newcomer has taken (most of) my moniker. Goodbye everybody. It has been fun.
    DD
  6. DinoDanGT
    DinoDanGT Rookie
    Aug 11, 2010
    3
    Minnesota
    Dan Bruggeman
    I apoligize, I hadn't seen a Dinodan moniker.
    I hope you're not going away mad.
    I'm am willing to change it.
    As I;m new to the FChat I'm excited to have this resource.
    I've had the car under restoration for almost 10 years now and are finally able to start driving it.
  7. UroTrash
    Jan 20, 2004
    40,486
    Purgatory
    Clifford Gunboat
    Awww, don't mind DD, he's just suffering acute Dino withdrawl.
  8. dm_n_stuff
    Dec 10, 2003
    43,725
    26.806311,-81.755805
    Dave M.
    And from personal experience I can tell you it lasts a
    LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONG
    Time. :D
    DM
  9. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    DONT put this oil in if you want smooth gearchanges...........I had my box rebuilt with all new syncros and bearings (by Ron at Superformance) ran for the first 500 miles with cheap oil and all was good (usual slight baulking in 2nd gear when cold) replaced after running in period with the Castrol SAF XJ bought from Superformance at their recommendation at no small expense!....It was awful, box baulked in EVERY gear and was so bad i dumped it out and replaced with another type which was suitable ( forget what it is now!!!) and gearbox is now excellent.
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Iwould be careful with using a fully synthetic oil, some ferrari guys have had problems with this oil. Any normal hypo 80 oil is good enough. Must be suitable LSD though
  11. Dino Club Germany
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    Strange. I have it in my rebuild gearbox since 10000 mls with no problems?
    Would be interesting what is better.
  12. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    Sure Dan, I can accept that, but then what, no more Dino? Never? Sure...
    Stick around.
    Best regards, Alberto
