Transporting a 328 by trailer - how best to tie down | FerrariChat
Discussion in '308/328' started by LuigiVampa, Jan 20, 2020.
  1. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    I'm going to be taking my 328 GTS to the shop in the next few weeks and in order to avoid an Uber ride I am going to bring it using my trailer.
    Any tips for strapping it down other than to lace the straps through the wheels? I dislike strapping through the wheel spokes as one crank too many on the strap takes the car out of alignment.
    Does a 328 have any tie-down points?
    Many thanks.
  2. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    From what I understand, Ferrari's should be tied down by the wheels only by straps running over the top of the tire (ideal) or through the wheel openings. Be careful not to run a strap over the valve stem. Doing this allows your car to "float" on its own suspension which can help absorb the bumps and bruises the road will dish. Trailer suspensions are not that great. Be sure to tie down all four wheels so the car won't jump.
    smg2, GatorFL and Nuvolari like this.
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,411
    Toronto / SoCal
    Rob C.
    Exactly correct
  4. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
  5. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    I've towed both by strapping down the suspension and tires depending on the vehicle and if there are suspension points to strap to. There are lots of opinions about tires versus frame and I cannot say that I am married to one idea. That being said, I threw one of my cars suspension out of alignment a bunch of years back because I overcranked the strap. I've learned to get snug but not overly snug.
    All that being said, does the 328 have any suspension pickup points? Being so low to the ground it will be hard to find them until I see the car on a lift.
    F612 - nice trailer! I used to use a block bolted to my trailer back when I only had one car to move around and I think it is an excellent idea. Unfortunately/fortunately, that ship sailed a long time ago!
  6. LuigiVampa
    LuigiVampa Karting
    65
    Todd
  7. 328GTSinPA
    328GTSinPA Rookie
    Dec 22, 2019
    42
    PA
    David Felker
    So, when we picked up mine last week, the Provost Motorsports guys did use the wheel straps through the spokes. We were very careful not to over tighten the ratchet and we took a slower than normal ride from Long Island to Bucks County than we otherwise would have done with the Cayman race car in the back. LOL!
    Car did not move. Here is the cautionary note: My mechanic drove the car onto the trailer as we really didn't know where to safely attach the winch to the front of the car. I then held the door open with my hand between the door and the wheel wells of the trailer so we would not scratch or dent the door. If the mechanic had not been a thin, fit 30 something, I don't know how the hell we would've gotten him out of there.
  8. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    The only car I own that I can drive into the trailer and get out easily is a 1953 MG TD.
    I know Provost - good guys! If you race a Cayman chances are we know each other.
  9. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Long tow with a race car, tie through suspension/mount. 500 miles of towing with only tires held in place is 500 miles of suspension wear. Going to a show is a different matter, over the wheels or through them is fine best would be something like this : https://www.harborfreight.com/search?q=wheel%20tie%20down%20straps.
    YMMV
    Lester
    LuigiVampa likes this.
  10. 328GTSinPA
    328GTSinPA Rookie
    Dec 22, 2019
    42
    PA
    David Felker
    Todd, it's me...David Felker.
  11. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
    Thanks for the compliment, the “decoration “ was a labor of love.
    I use the same trailer with spacers for my 575, Morgan 4/4 and Porsche 991.
    I have towed them 1000s of miles
  12. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    Let's say hello at the next race we are both at. Looks like no Sebring for you this year - maybe LRP or WGI? I'll be there.
    I have different parking positions for most of the cars as there are front, mid, and rear engine cars in the menagerie. Where the weight goes affects the ride. I have a good weight distribution hitch but it does matter.
    Except for the MG as that weighs nothing and I can park it where ever it ends up!
  13. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    No, I'm David Felker!
    Lester
  14. 328GTSinPA
    328GTSinPA Rookie
    Dec 22, 2019
    42
    PA
    David Felker
    LOL!
  15. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    The 328 has one tow hook welded to the underframe passenger side. But having only one is not enough to tie down four corners.
  16. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    That's really what I wanted to know - thank you. I don't plan on hauling the car for long distances so strapping down the wheels should be fine.
  17. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I've hauled 308, (2) mondis and two 348's as well as a lotus esprit back form atlanta to MN. I always loop through or grab the lower a arm as close to the wheel as possible. And the lower a arms in the rear criss crossing the rear straps for stability. Never really tried the over the wheel approach. Mostly because of the low front spoilers on theses cars you'd have to have tie down points available very near the front and back of the wheel/tire. I've also never been a fan of the through the wheel idea because even with a towel or other protection I would personally worry about damage to the wheel finish. I've seen the through the wheel technique plenty though.
    87testa likes this.
  18. dinoart
    dinoart Formula Junior
    756
    Westminster CA
    David
    I do the same technique as yours hauling Dinos, 308s, 512M, California, SUVs in my 24 feet trailer to Northern California from So Cal with no troubles or change in alignment. The latest trip was to FCA Scottsdale AZ with the 308. I must say I try to avoid wrapping through the wheel technique since I might scratch the wheel's finish on my 98 points car while looping the straps in low light condition.
    87testa likes this.
  19. LuigiVampa
    LuigiVampa Karting
    65
    Todd
    Agreed. Over the wheel is generally not a consideration with low cars as there is not enough clearance to crank the ratchet.
    Good news is that I was able to find the time to get a temporary registration for my car so that when it is delivered tomorrow I can just drive it home from the parking lot we are meeting at.
    All that being said, I'm certain the car will be going to the shop soon afterwards for a full checkup so it has a date with my trailer in the near future.
  20. ragtop1
    ragtop1 F1 Veteran
    5,002
    Ontario
    Larry Warren
  21. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,540
    Cerritos, CA.
    I don’t have an inclose trailer but when I had to transport my QV 250 miles I just rented a U-Haul trailer and it works great.
  22. Du_Man
    Du_Man Formula Junior
    278
    Dallas, Texas
    Derek
    +1
    miketuason likes this.
  23. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Yes they work surprising well. I've moved a mondial, 308 and 2 348's with them in a pinch. They require a few extra steps/tips and techniques to get the cars on , but yes they do in fact work well.
