Traqmate Tach reading on a 355 question | FerrariChat
Discussion in 'Other Racing' started by vlamgat, Dec 7, 2012.
  1. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    Has anyone been able to get their Traqmate to show RPM when fitted to a 355?
    I have tried to pull a signal from the tach and from the coil, with and without changing the dip switch in the Traqdata II box; and with and without fitting a Motec tach sender unit between the coil signal and the Traqdata II. Nothing at all just a zero.
    I have tried another Traqmate, no difference and I have successfully pulled the tach signal to shift light.
    Any other suggestions appreciated.
  2. JFatigati
    JFatigati Karting
    Apr 10, 2011
    57
    New York
    John Fatigati
    Rob-
    Give Jim a call at Pocono Sports car. I have one in my car that works, but don't ask me how he did it! Happy Holidays!
  3. vlamgat
    Jan 9, 2004
    776
    Spoke to Jim - thank you. Yours is pulled from the green wire tach signal. I had tried that without success but ti may be because I already have a shift light being driven by that cable and I am diluting its output. So I am going to have another attempt.
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Yes, try connecting to the green tach lead again. Also, Fast Ian has done that on his.
  5. vlamgat
    Jan 9, 2004
    776
    Could not get any 5 volt circuit to work. Finally went with a 12 volt circuit driven off an injector and configured at a 1 cylinder engine.
