360 - Tri Y Header Options | FerrariChat
360 Tri Y Header Options
Discussion in '360/430' started by Wrinckled, Dec 7, 2021.
  1. Wrinckled
    Wrinckled Rookie
    Mar 16, 2021
    26
    Kyle
    I'm looking to stick with the tri y header design from Ferrari, however, it looks like all the aftermarket is 4-1. Does anyone know of a vendor that provides tri y design?
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
  3. Wrinckled
    Wrinckled Rookie
    Mar 16, 2021
    26
    Kyle
    The shop I use here is a bit old-fashioned. If I gave them the euro headers to place on my US car, what modifications would they need to make in order for there to be no CEL?
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    Definitely a tune from AV which I'm using and absolutely love. To gain full purpose of no precat But they bolt right on.
  5. Wrinckled
    Wrinckled Rookie
    Mar 16, 2021
    26
    Kyle
    Isn't there a rail on top the US spec that isn't present on the euro?
  6. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    Some had and some didn't. My car is a 99 so none
  7. priericky128
    priericky128 Formula Junior
    703
    St. Louis MO
    Rick
    There are some euro headers with air rails and others without.
  8. RedTaxi
    RedTaxi F1 Rookie
    3,340
    New Zealand
    Glen
    From those pictures in post #2 360 headers appear to be 4-1. Compared to 430 headers which are 4-2-1 tri-y with quite short primary tubes.
  9. 550nitis
    550nitis Formula Junior
    760
    Houston
    They are beautiful! Are you running Euro headers in your car then. How is the sound? Also do you get more resonance since the heat shields are not there?
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    I have a extra set or at least 1 left side. My car is a 99 and they have the heat shields on .right now but my goal is to remove the shield and have them coated .
  11. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    That picture is both 360 manifold one is a 4 to 2 to 1 and the other is a 4 to 1
  12. 550nitis
    760
    Houston
    Do you have the an extra set of the euro or US?
  13. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    I have one extra left euro and 1 right us cat header. And the 2 in my car
