Trickle charger for 599 | FerrariChat
Discussion in '612/599' started by abilliet, Nov 16, 2015.
  1. abilliet
    abilliet Formula Junior
    Dec 5, 2006
    403
    Antony Billiet
    Any suggestions about the most efficient battery maintenance charger for a 2007 599 ?
  2. DXB599
    DXB599 Formula 3
  3. BJJ
    BJJ Formula 3
    1,301
    Just take the Ctek only and place a notice in the car to prevent you from driving away with the charger still attached (if you really believe that this necessary) ;).
    Most simple approach would be to permanently fit the comfort connect eyelet provided with the Ctek device. There are various options for that, in particular near the factory socket in the boot.
  4. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
  5. tazandjan
    39,067
    Not sure the 2007 has a port for a factory CTEK. They became standard in 2008 MY.
  6. cam612
    cam612 Karting
    Jul 22, 2014
    79
  7. DZ-96
    DZ-96 Formula 3
    1,893
    South Germany
    Daniel
    Taz
    Mine has the connection : 157967
    Perhaps the connection came with the Motronic update ?
    Daniel
  8. Piper
    Piper Two Time F1 World Champ
    25,415
    Northern Virginia
    Bob
    I have a nice ctek I don't need.
  9. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    You may need it someday soon, again :) ;)
  10. tazandjan
    39,067
    Daniel- I believe it did. US SN 156938, or that may be the universal serial number for the change.
  11. DZ-96
    DZ-96 Formula 3
    1,893
    South Germany
    Daniel
    When the charger is connected and you turn on the ignition, you get a warning signal in the display.
    So the software is optimized for the charger.
    Daniel
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    When you attach the Ferrari Battery Maintainer into the port on F430s then the Dash illuminates a Battery Charging Icon and disables starting so you can't drive off with the charger attached.
    Is the 612 the same way?
    Does it use the same connector with a "U" for an outline?
    Do you have a photo of the charging port?
  13. cam612
    cam612 Karting
    Jul 22, 2014
    79
    #14 cam612, Nov 19, 2015
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  15. Veloce12
    Veloce12 Karting
    Aug 19, 2006
    154
    Southern California
    Brady
    Best is Granite Digital. Check it out on granite digital.com.
