Trickle charger or Battery Tender | FerrariChat
Discussion in 'Technical Q&A' started by miketuason, Oct 31, 2006.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    What is the diff. between the two? is one better than the other? I need something to keep my Batt. charge while it is being stored for winter but I also need to warm it up once a week. Thanks.
  2. f355spider
    f355spider F1 World Champ
    18,044
    You want a battery tender. A trickle charger will give a continuous small charge to the battery...once fully charged it will overcharge and boil out the electrolyte. A battery tender will sense the full charge status, and stop charging...it goes into a "float mode" and will begin charging again, if the voltage drops below a predetermined amount. There are many brands and types of battery tenders, just find one that says "battery tender" or "microprocessor controlled" or "fully automatic". Something between 1 and 1.5 amps is sufficient (surprisingly, bigger is not necessarily better...I can put my fully automatic 2-15 amp charger on my battery and reach "full charge" indication pretty quickly, then attach my 1.5amp battery tender, and it will continue to charge it for another hour or two more to top it off). Walmart has a nice looking unit and only cost like $20 or $25...I forget the exact price, but it was very reasonable.
    Many of us use the Deltran battery tender, they sell for $50 to $60 but can be purchased online here for cheap:
    http://tinyurl.com/yb38px
    Personally, I'd get the Walmart one...they all basically do the same thing. For convenience, I would recommend buying a cigarette lighter adapter from Radio Shack, and add another 8 feet of 18 ga cord on it...makes connecting it up easier through the cig lighter (just close your door on the cord, it is not a problem), than using the pigtail you attach directly to the battery then thread into the trunk. Because then you have to open the trunk each time to make up the connection. Also, using the cig lighter, you will never drive off with the thing connected. ;)
  3. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Thanks davehanda, that answered my question I guess battery tender is the safe way to go. I didn't know that a trickle charger will boil out the acid by means of over charging, anyway thanks again.
  4. Ricambi America
    Sponsor Owner
    My baby is on a Tender... works like magic.
  5. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    Battery Tender, end of discussion. They do the job without any problems.
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    You can look at an Interstate unit also, Mike.
    Local auto parts store will have it.
    BTW, what are you going to "warm once a week"?
    The battery tender or the car?
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Battery Tender - got mine at Pep Boys.
    It's a miracle cure for nearly all Mondial electrical weirdness
  8. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Simply unhook the battery until you need to start the car. Takes less time to disconnect the (-) cable than it does to mess with a trickle charger everytime.
    In CA the battery wont freeze if left in the car and if it's actually in storage, why leave any power on and have potential for things to go wrong.
    The battery wont go dead (unhooked) in a week or two and will get recharged if you drive it every other week or even bring the car up to temp periodically.
    For storage in WI I pull the battery from the car throw it in the basment for 6 months & when I pull it out it still has the power to crank/start the car.
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Could that be from all the cheese in Wisconsin?
    You don't have happy cows, however!
  10. f355spider
    18,044
    One reason not to unhook the battery is that you then have to reset the clock and radio presets each time (and the clock function on the radio too).
  11. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Greg I meant to warm up the car or even drive it a few miles just to get it up to normal operating temp once a week or even once every two weeks.
  12. DGS
    DGS Seven Time F1 World Champ
    71,911
    MidTN
    DGS
    You can also get some inline connectors (make sure they're rated for the current). That way, you can connect either the battery terminal clamps or the cig lighter plug to the tender.
    Now if I could work out the docking system that connects up the tender as you pull into the garage ... ;)
    (I used to joke about getting those NASA LEM docking targets for putting three cars in an oversized single garage at the last condo. :p)
  13. Paul93Lotus
    Paul93Lotus Rookie
    Oct 4, 2006
    1
    Camarillo, CA
    Paul Andre
    A bad side effect to disconnecting the battery will be that if the ECU for your vehicle does any 'learning' and stores engine data within the prom, all that memory will be lost. Each time you go for a drive it will take about 15 minutes for the car to 'relearn' for optimum performance. Here is a inexpensive battery tender that works well for my Lotus (and its quirky Lucas electronics):
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42292
  14. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
  15. f355spider
    18,044
    Battery Tender is both a brand and a description. I think the best way to differentiate the types is that "trickle chargers" are "dumb"...they give the battery a contant charge, even though small "a trickle..."...where as a "battery tender" is "smart" and knows when the battery has reached full charge and stops charging, until the voltage drops low enough to require charging again. Here is the relevant description from the Battery Tender sales literature:
    "Coupled with a brain (IC chip), the charger will constantly monitor, charge, and then maintain your battery"
    So Battery Tender, Microprocessor controlled or "smart charger" is good....."Trickle Charger" is BAD!
  16. f355spider
    18,044
    BTW, that one is pretty small (800 milliamps) and usually used for motorcycles and snow machines. Will work for a car battery, but could take a loooooooong time to top up a partially discharged car battery. For maintanence charging it should be just fine though.
  17. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    Mine is a Battery Tender Junior, only 750 ma. but works fine.
  18. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    It has more power then the Jr. and is total enclosed, meaning safer in wet environments. I don't need a full charger because I already own one. This is for keeping the battery in great condition, not recharging. Though I've used it to bring a battery back to full charge after jumping a Jeep Grand Cherokee.
    I'd rather have a small unit like this on my car then a full charger.
    Further, this is what Deltran recommended to me. It worked so well I bought two more.
  19. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
    The car battery also helps keep the charge in the alarm/security system so if your car gets stolen you may not have a working alarm or tracker system.
    Once the insurance company hears your car was parked with no alarm system that can often stom them paying out to cover loss.
  20. fiorano94
    fiorano94 F1 Veteran
    May 26, 2006
    6,892
    MW/NW/SE
    Your "baby" is one of the best 348's out there too! Sorry pap, I'm a sucker for a black car!
  21. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    I have a Schumacher battery charger. http://store.schumachermart.com/sc-1200a.html I like it because is does both charge and maintain the battery. It has three different types of amp charging 2/8/12, so if you want to charge the battery fast it can. Also once the battery it at full charge it will stop, and then turn on if the voltage falls below 13.0, well that's what I have noticed anyway. I use it if I'm not gonna drive the car for a couple of days, because these stupid cars love to drain batteries. Now if I'm going to let the car sit for longer than a week then I just disconnect the battery altogether.
