Trickle charger question | FerrariChat
Discussion in '360/430' started by mrpcar, Jan 11, 2008.
  1. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Have some trickel charger questions:
    (1). When do you guys decide to hook it up to the car? if car is parked for more than 2 days, or a week? I plan to drive my car at least once a week.
    (2). Do you guys use the factory trickle charger that came with the car? Or some other units?
    (3). I heard that some people have a wire behind the driver's seat where they hook it up to? What is that? An owner added option? Where do you tap the wires to?
    (4). When car is on trickle charger do you guys turn off the main battery switch?
    TIA
  2. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    Here are a few threads regarding trickle chargers and 360's
    http://www.ferrarichat.com/forum/showthread.php?t=127183&highlight=trickle+charger
    http://www.ferrarichat.com/forum/showthread.php?t=121179&highlight=trickle+charger
    http://www.ferrarichat.com/forum/showthread.php?t=137231&highlight=trickle+charger
    http://www.ferrarichat.com/forum/showthread.php?t=110301&highlight=trickle+charger
  3. vnttg
    vnttg Formula Junior
    Jun 13, 2007
    262
    CA
  4. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    I plug my 430 into the factorr-supplied charger when ever I park the car in my garage. Reason is I never know how long it'll be between drives and always want the battery topped off.
    Frank
  5. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    The only reason why I am considering other battery tender questions is that I have read numbers of posts saying that the Ferrari unit is junk, can cause battery drain.....
  6. 900ssDuke
    900ssDuke Karting
    Sep 12, 2007
    214
    1 Every time I put the car in the garage. Any more than a week ignored and my new battery can let me down. I know that if you get the chance to use these cars regularly you might not need a trickle charger.
    2 I did not get a charger with the car, I purchased an Accumate as it was a fraction of the cost
    3 My 360 came pre wired for a charger in the trunk (remove a panel below the wnidscreen to access.) It was a pain to get to, my cigarette lighter is live with the keys removed so I use it.
    4 I leave the main battery switch on so that the doors locks and alarm operate
    regards,
    AndyB
  7. davidkuola
    davidkuola Karting
    Feb 26, 2007
    107
    Arcadia, CA
    David Kuo
    (1) After drive the car everytime, I always plug in battery tender (black box w/wire) to the prewired pig tail plug. Until the green light is on, then unplug it.
    (2) No, it's a crap (the old style).
    (3) This is the way to go. Go buy a "Battery Tender Plus" (brand name) It comes with tender and wire/pig tail. Then get a F-mechanic (or go back to AG, it should be free for the 5 minute job)to install the pig tail. Make sure wire it behind the driver seat. Don't connect it from the passage side foot well battery directly. Other than from Internet, you even can get the tender from local Harley davidson dealer for 60 bucks only (that's how I got it).
    4) No.
    P.S. 360 has less battery issue than 430, I'm not going to worry about it for not having a "life support" in weeks. NOW it's the time to have lots of fun with your new car, and you DO need to take that HOT Ferrari out EVERYDAY.
  8. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Where exactly do you hook the pigtail on behind the driver's seat? I don't think I want to drive all the way back to AG to get this done. I saw some posts that people were hooking the pigtail up the the red post on the passenger (right) side.
  9. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    I had AG install this on both my cars. It's easy and inexpensive and very convenient. I don't use my charger much because I drive the car almost every week. If I'm not going to drive for over 2 weeks then I hook it up.
  10. Skidkid
    Skidkid F1 Veteran
    9,644
    Campbell, CA
    John Zornes
  11. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Same procedure here.
  12. davidkuola
    davidkuola Karting
    Feb 26, 2007
    107
    Arcadia, CA
    David Kuo
    In between the drive seat back and rear bench shelf, there is a one step up flat area (bench?), underneath of the carpet, you will find lots of wires. That's the ONLY correct spot to do the wiring. Or call Eugino 626-4847933. He is a great guy.
  13. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    I've been using the supplied Ferrari OEM charger.........absolutely no problems. It works fine.
  14. SKXF430
    SKXF430 Karting
    Oct 19, 2004
    164
    W. Los Angeles
    I think if you drive your car once a week than your battery should be fine. Do you arm your alarm every time you put it in your garage? That is creating most of the drain on your battery so if you don't have to don't arm it.
    Also, what year is your car? If it is a late '07 or '08 than a battery charger came standard with the car.
  15. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    I have F-OEM charger and my car is pre wired and the charger never turns on the little led !!!!!!!!!!!!!
  16. Tarek K.
    10,798
    Cairo - Egypt
    Tarek K.
    What year is your F430?
    I have the older version charger on my 2007. The lights on the charger should go from red when first plugged in to orange then green when fully charged.
  17. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    07 and I tried to use it several times and nothing happens with the leds always off the car runs ok after 3 weeks of no use....Don't understand I took the battery tender to a F dealer and they said it was ok but they also mention that one time they has to do something to the electrical installation of this item in another car to make it work...
  18. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    I do the same but hook up to the Deltran battery Tender which gets good mention in the threads that were supplied on this subject
  19. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    +1
  20. Steve R
    Steve R F1 Rookie
    3,018
    MeSoNeedy, CA
    TorQ Master
    It's all very simple....
    IF you hook-up your charger...you'll end up driving the car the very next day or even out for dinner later that night.
    If you decide not to hook-up your charger, you'll likely go 3 weeks before turning the key again.
    :D :D :D :D :D
    One day....I'm gonna invent a small device that runs on it's own 9-volt battery, it'll plug into your cigarette lighter and just sit there. When the battery drops below a certain level it'll start beeping. One day you're wife will tell you the Ferrari is beeping and you'll realize it's time to run out and plug in the battery tender before things get problematic. Oh the practicality.....but where's the fun???? ;)
