Trickle Charger | FerrariChat
Trickle Charger
Discussion in 'California(Portofino)/Roma(Amalfi)' started by dolphins08430, Jul 7, 2015.
  1. dolphins08430
    dolphins08430 Formula Junior Silver Subscribed
    Jun 2, 2011
    450
    Hello All- I'm unable to find where you plug in the trickle charger on the Cali T?
    Thanks!
  2. Gb135
    Gb135 Karting
    Jul 28, 2014
    94
    its an exterior plug located to the left of the rear license plate
  3. dolphins08430
    Jun 2, 2011
    450
    Thanks!
  4. Alcav5
    Alcav5 F1 Rookie Rossa Subscribed
    Jul 28, 2012
    4,091
    West Harrison, NY
    Al
    timjen88 likes this.
  5. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Sorry to see that. I assume that's from your OEM battery tender, but doesn't your car disable ignition when the battery tender is connected to it?
  6. Alcav5
    Jul 28, 2012
    4,091
    West Harrison, NY
    Al
    I am thinking no big deal, I do not think I dasmaged (ran over) the charger.
    I just opened up the connector housing and reattached the wires, albeit a bit tight.
    On on my 201 Cali , yes the car would not start with the charger connected , this one obviously started and let me back away..... I read this before & I guess it didn't sink in. Whatever so far I think I am ok, will see tomorrow.
    A
  7. Udaverea
    Udaverea Formula 3
    Jun 9, 2014
    1,149
    Western Tennessee
    Dave
    I've done that but it just popped off, depends on the angle of where the cord goes, I suppose. It was formerly plugged in from the far side of the car as approached in the garage. I moved it to an outlet where I CANNOT miss that it is plugged in now.
  8. dfranzen
    dfranzen Formula 3 Owner
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    buy a REMOVE BEFORE FLIGHT tag
  9. Alcav5
    Jul 28, 2012
    4,091
    West Harrison, NY
    Al
    Well I just went to put the car away for the week and I connected the charger.
    Now red light on the charger is on (above the light is an exclamation point - or a something is wrong point as I'm thinking). It's hard to see in the picture, but if I recall last time that red light was not lit, the other lights (amber I believe) would be lit...
    I wonder if I damaged something inside the car's connection unit?
    I'll read on it later.
    Anyone seen this before, or have any ideas?
    Thanks, I'll be back on later.
  10. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    The RED (!) LED lights up if you have reverse polarity. You reconnected the wires incorrectly.
  11. HDN
    HDN Rookie
    Apr 7, 2018
    22
    Herman N
    tomc likes this.
