Trickle Chargers and Condo Boards | FerrariChat
Discussion in '458 Italia/488/F8' started by misha, Sep 19, 2017.
  1. misha
    misha Karting
    Sep 13, 2017
    56
    I would assume that most people here don't have this issue, but I live in a condo in a downtown area, and I was asking about the use of plugs in the garage for the trickle charger for my 488 for when I travel or if I don't end up driving the car for a bit.
    The condo board is being very condo board about this, saying that I will need to do the research on how to get a meter installed, then propose it at the next board meeting etc etc.
    I'm trying to see if there is perhaps a simpler way to go about this before going down the condo board rabbit hole. I know they have battery powered chargers for dead batteries on normal cars, is there anything like that out there than can safely and effectively be used with a 488 if I were to leave town for say a month or so?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    #2 greyboxer, Sep 19, 2017
  3. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    Our Condo Board didn't bat an eye. They quoted the cost to install the electrical plumbing and an upper estimate of $30 a year for juice. They've installed a meter to measure the usage and will adjust the cost accordingly. But as Jimmie stated, it will be on the order of pennies per month.
  4. boobernackle
    boobernackle Formula Junior
    May 28, 2016
    963
    You can leave a 488 sitting for at least 1-2 months and still be fine. Just remember to start the car up, rev the engine a bit to charge the battery and drive around for 15-30 minutes to allow for the battery to charge again. Make sure you don't have anything plugged in to drain the battery.
    Trickle charger is for when the car sits for 4-6 months at a time.
  5. misha
    misha Karting
    Sep 13, 2017
    56
    Oh wow, the dealer told me if the car was sitting for a week or longer I should use it. If I can leave it for a month or two without worrying then this becomes a non issue. I know you have one, have you let it sit without charging for a while?
  6. misha
    misha Karting
    Sep 13, 2017
    56
    I'm gonna see if I can figure out what it draws and then I'll present it to the board! Thanks!
  7. Lotaz
    Lotaz Formula 3
    Nov 18, 2016
    1,537
    Las Vegas
    Scott
    Heck I would just offer them something around $24 a year for using it and send them the ~ figures and see what they say. I would think $2.00 a month is fair.
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    Nonsense ! (imo :) )
    If you have followed the many threads here, you would have read quite the opposite Boobernackle, sorry !
    Lot's of unexpected faults occur with cars that have been off the charger for more than one week.
    on1wheel and of2worlds like this.
  9. Jatus24
    Jatus24 Rookie
    Dec 30, 2014
    36
    Los Angeles
    My 488 cannot last longer than 5-6 days without being plugged into the charger. there were a lot of faults when i had the car jumped by Ferrari roadside service after being away for ten days. the driver told me that it should always be plugged in if the car will not be used for at least 48 hours to be safe.
    of2worlds likes this.
  10. boobernackle
    May 28, 2016
    963
    Then there's something fundamentally wrong with your car. I have left my 488 sitting for weeks without being on the trickle charger without issue, same thing with my Cali T and others.
    Yes, it is a Ferrari, but it still relies on the same technology to start the car as a Honda...
  11. MJR_HK
    MJR_HK Karting
    Aug 9, 2016
    50
    HK & CH
    Every time I return home from a drive, I connect the trickle charger. Became a habit like brushing my teeth. Never had a problem.
    In HK I have the same issue with the incorporated owners management board, unwillingness to install a socket and meter...and my cars are dead after sitting 2 months in summer, replace my batteries basically once a year. Guess the immense humidity we have here adds to it, too.
    I tried solar panels which plug into the 12v socket of the car, but they didn't do the job either. Maybe not enough light.
    Try to get your own socket and meter installed and use the trickle charger all the time - I think that's best!
  12. Hoagers
    Hoagers Karting
    Dec 4, 2016
    166
    I know few Ferrari's no Merc's, Jag's that can be left for weeks untended and not expect the electronics gremlins to get ugly. I hear a few owners that say it's fine, FAR more that have issues that were quickly resolved by getting a new battery then maintaining it. You bought your ticket, you take your chances
  13. Cigarzman
    Cigarzman F1 Veteran
    I’m in the same position , no outlet , high rise. What I do is cover the car without locking it because the alarm system will drain your battery after 2 weeks. Trust me I’ve learned the hard way. My car is driven every 7-10 days with no problems. I’ve not had an issue for the last 2 years doing it this way. Best , Kirk.
  14. RossoCorsa716
    RossoCorsa716 Karting
    May 15, 2017
    116
    Los Angeles, CA
    The 488 seems to be more sensitive to non-use than previous models. Not sure if the upgraded anti-theft system (which seems to monitor every aspect of the car) has something to do with this.
    I live in a condo as well and we don't have any plugs. I've gotten in the habit of starting the car at least every 3 days and letting it run for 10 minutes. Usually I'm able to take it for a morning coffee run down the street every other day or so. But, I'd play it safe and start the engine at least once a week and let it run.
    You'll get weird notice lights coming on if your battery charge drops even a little bit (like check engine, etc.) that will freak you out. Most of the time if you let the engine run and then restart the car those lights disappear.
    Bigger issue is to let your detailer know to turn off all lights while car is being cleaned. That tends to drain battery pretty quick.
    Cheers!
  15. tobewiser
    tobewiser Formula Junior
    Dec 23, 2015
    347
    Acworth, GA, USA
    #15 tobewiser, Sep 27, 2017
    A $200 solution?
    An obvious solution seems to be a battery powered portable AC power bank. e.g.: https://www.amazon.com/Generator-Portable-39600mAh-Rechargeable-Inverter/dp/B071LHL43X/ref=sr_1_3?ie=UTF8&qid=1506530143&sr=8-3&keywords=portable+120v+power+supply
    You can plug in your OEM charger into the 120v AC outlet. This solution works well for the 458 whose connector is inside the car; and therefore both the power units are placed inside the car. The 488 may require some creative origami in order to conceal the power bank and the charger inside the engine bay. It may still be a more practical solution than overcoming bureaucracy and/or physical limitation of wiring an AC outlet in a public garage. Even if you can get an AC outlet wired in the garage, your charger will still have to secured in order to prevent theft. Since the charger uses little power, the power bank itself will last for quite a while before needed charging. My experience with my fully charged 458 battery (1 year old) shows that 10 days (temperature < 45F) or 15 days (temperature >45F and <90F) is the longest you can start without issues. The 458's parasitic power drain is the highest of the 50+ cars my family has ever owned. This is not unique to modern Ferrari's but it is worse than many other exotic brands.
    I also wish Ctek would make a li-ion portable charger specifically for this application.
  16. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,605
    AZ
    Rick
    Tell them it's a hybrid. They will probably bend over backwards to get outlets installed if they think they're being "green."
    Jeremy, CarbonDan and of2worlds like this.
  17. flifer
    flifer Karting
    Mar 3, 2016
    162
    Miami
    Has anyone ever used a power bank before for a trickle charger? Do you think it would last for weeks?
  18. Melvok
    Jul 25, 2008
    14,263
    Mel
    Are there powerbanks of 12 volt ? You mean an extra (big) car battery ?
  19. flifer
    flifer Karting
    Mar 3, 2016
    162
    Miami
    I was referencing a previous posters suggestion of... I didn't think it was feasible to use something like for a trickle charger
    I currently own this jump box. But it can only charge the car for 7 minutes https://www.amazon.com/gp/product/B01MU1CPOE/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
  20. Melvok
    Jul 25, 2008
    14,263
    Mel
    Why not an extre car battery (portable) ... only if nessesary .... or as precaution if nothing els is available ...
  21. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    Love it!
    Regards
    Michael
  22. dustman
    dustman F1 World Champ
    11,431
    Read.
  23. misha
    misha Karting
    Sep 13, 2017
    56
    It's looking like this is going to be what I will have to do unfortunately, they are choosing to be difficult about this for typical condo board reasons. It's pretty damn annoying.
    With that said, does anyone have recommendations for a good external battery that I could use to run the trickle charger?
  24. flifer
    flifer Karting
    Mar 3, 2016
    162
    Miami
    Can anyone else chime in and say if this will be a good solution or not? Looks like it could be a better solution than buying an extra car battery to swap in once your original battery dies
  25. Melvok
    Jul 25, 2008
    14,263
    Mel
    That's not what was mentionned imo ...
    We thought about an extra battery, connected to your 12 volt carbattery during storage, like a trickle charger.
